Old May 26, 2016, 04:18 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Fuel System Guides
Print Wikipost
How to run your LS1 on E85
Old Sep 16, 2007 | 09:47 PM
  #161
vaticano's Avatar
Default new dyno results
these are corrected numbers, the correction factor was 1.21
642.1 rwhp 593.5 rwtq it was 533 rwhp here in denver.
before the D1 i dynoed 383 rwhp 385 rwtq, but this was untuned and had about 40 more hp in it
Old Oct 10, 2007 | 03:38 PM
  #162
Mia's Avatar
Mia
subscribing
Old Oct 11, 2007 | 03:25 PM
  #163
Mia's Avatar
Mia
what has to be done to use e85 on a turbo car? just increase fuel?
Old Oct 11, 2007 | 03:52 PM
  #164
fil131's Avatar
fueling and you can get away with more timing because of the higher octane
Old Oct 11, 2007 | 06:09 PM
  #165
vaticano's Avatar
as well as more boost
Old Oct 12, 2007 | 09:37 AM
  #166
Mia's Avatar
Mia
so you couldn't just run it in a turbo car without a tune for e85?
Old Oct 12, 2007 | 09:55 AM
  #167
LS2Camaro's Avatar
Depends on how much your already pushing your fuel system. Your fuel system needs to be able to handle more than with unleaded fuels. If your pump cant handle at least 15% more fuel, you will run lean, than BOOM!!!
Old Oct 12, 2007 | 01:15 PM
  #168
fil131's Avatar
You deffinitely need tuning, gasoline and ethonol compress differently, and have totally different Stoich AFR's
Just make sure you have big enough injectors and a pump setup that can handle the flow.
That and tuning should be enough, but the info is kinda sketchy on whether or not the ethonol will eat any part of our cars.
Take it fwiw, I have read thread upon thread of ppl in LSX equipped vehicles with no other changes than the ones listed above.
Old Oct 12, 2007 | 01:47 PM
  #169
vaticano's Avatar
all i changed, in the tune was the stoich value, i already had a fuel pump and 42 lb# injectors. there are companies that sell conversion kits that you plug in in-line with the injectors and it adjusts the fueling, but if your fuel system is not up to it it wont run properly. as for the BOOM, part, mine ran at 14:1 AFR on my wide band, at 6500 rpm and 8.4#'s of boost, made 642 rwhp and there was not a hint of knock retard, and no Boom. this stuff is real safe when it comes to preignition or detonation. stoich is 9.8:1 and max power is at 8.5:1. 14:1 would blow a gas motor at those levels but didn't even flinch in mine. but the fuel system needs to be upgraded, i'll likely have a few more ponies in there when i get the new set-up
Old Oct 12, 2007 | 01:51 PM
  #170
Mia's Avatar
Mia
who is one of those companies? I have a female friend that has a Volvo turbo and she would be greatfull if she could use e85. I do not know anyone who could tune it, so she could use it otherwise.
Old Oct 12, 2007 | 01:54 PM
  #171
vaticano's Avatar
http://www.change2e85.com/servlet/StoreFront here is one but there are several, just google it
Old Oct 12, 2007 | 02:08 PM
  #172
fil131's Avatar
I really dont see how the everyday drivers are soo interested in this transition, E85 is so more viable for the high performance high compression racer or even daily driver who just wants to have best HP at all times, this will not make your car a "green" car or make fueling cheaper for you.
Old Oct 12, 2007 | 02:13 PM
  #173
LS2Camaro's Avatar
Originally Posted by fil131
You deffinitely need tuning, gasoline and ethonol but the info is kinda sketchy on whether or not the ethonol will eat any part of our cars.
Actually, I have also heard those rumors, thats all they are from what I have seen is rumor though. I have yet to hear or see any pics of any 80's or newer model fuel system getting corroded or eaten by ethanol, in fact its much cleaner than unleaded fuel, and will in fact clean out your dirty fuel system that has been run by unleaded for many years. It is recommended you change out your fuel filters out after shortly running ethanol from all of the mess unleaded fuel left. Show me a link where corrosion has happened due to ethanol??
Here is a few links of high HP cars running Ethanol, I dont think its corroding there fuel system. As Runn has said earlier in the thread, thousands have used it and none have had the problem of corrosion. Do you think this 900rwhp Mustang would run strictly E85 if it ate his fuel system, would you want to chance a build like that? Oh and by the way, Brazil last I checked was running 22% ethanol in ALL of there pumps, and lots of pumps in the US are offering 10% mix. There must be alot of corroded Cars out there
These guys are running a 1000rwhp mustang, nothing fancy about their fuel system except of course bigger injectors and pump.
http://www.theturboforums.com/smf/in...?topic=47094.0
http://www.greencar.com/index.cfm?content=mustang-e85
http://www.rune85.com/turbocobra
http://e85mustangs.com/
http://en.wikipedia.org/wiki/Ethanol_fuel_in_Brazil
Old Oct 23, 2007 | 09:20 PM
  #174
MJU1983's Avatar
Originally Posted by Runn
Fuel ........................ AFRst ........ FARst ....... Equivalence Ratio ... Lambda
Gas stoich ................ 14.7 .......... 0.068 ................ 1 ................... 1
Gas max power rich .... 12.5 .......... 0.08 ................. 1.176 .............. 0.8503
Gas max power lean .... 13.23 ........ 0.0755 .............. 1.111 ............. 0.900
E85 stoich .................. 9.765 ....... 0.10235 ............ 1 ................... 1
E85 max power rich ...... 6.975 ....... 0.1434 .............. 1.40 ............... 0.7143
E85 max power lean ..... 8.4687 ...... 0.118 ............... 1.153 .............. 0.8673
E100 stoich ................ 9.0078 ...... 0.111 ............... 1 .................... 1
E100 max power rich .... 6.429 ........ 0.155 .............. 1.4 .................. 0.714
E100 max power lean .... 7.8 .... ...... 0.128 .............. 1.15 ................ 0.870
I thought this chart and information looked familiar...sure enough, the above chart is from the testing of a member on NASIOC named hotrod.
http://forums.nasioc.com/forums/showthread.php?t=803341
If you credited him for his work, I apologize...but I didn't see any mention.
-Mike
Old Oct 24, 2007 | 03:03 PM
  #175
A502slo's Avatar
I kinda sorta maybe maybe not understand what you guys are saying here, but how do you rear AF?? my Af stops as soon as i hit anything less then 10.0-1 AF?? so what do i use to read the AF with E85
Old Oct 24, 2007 | 06:05 PM
  #176
BLK02WS6's Avatar
Wideband has to be calibrated to read lower numbers - some cannot be changed, others can...
Old Oct 24, 2007 | 07:09 PM
  #177
A502slo's Avatar
Cool, i have a new project for you now
lol you told me to stay 10 ft away from the Nos bottle
Old Oct 24, 2007 | 07:14 PM
  #178
BLK02WS6's Avatar
You better check availability in our area - I checked it with the thought of doing this last year and have been keeping an eye on it since - not too many places to get E85...
Old Oct 24, 2007 | 07:32 PM
  #179
vaticano's Avatar
when i had my car dynoed it was the same way nothing lower that 10:1 but when we ran the car the AFR showed up as it would have if it were running on gas, because the o2 sensor only reads in Stoich and the software converts it to AFR
Old Oct 24, 2007 | 07:45 PM
  #180
A502slo's Avatar
Oh you took my joke as been serious. When you ready to
Also when you ready to tune the V, its got the meth kit on there now.
