- Camaro and Firebird: What You Need to Know About E85 and Race Gas
Important information to help you understand your Camaro or Firebird.
Browse all: Chevrolet Camaro or Pontiac Firebird Fuel System Guides
How to run your LS1 on E85
Has anyone had to change the rubber lines in the fuel tank?
I noticed a drop of 5 to 6 psi under idle recently and thought something was going wrong with my fuel pumps. I have 2 walbros; 2nd one comes on under boost. I pulled the pump buckets and barely tugged on one of the lines and it came off!. I checked the other connections and all where loose. Did a little research and appears E85 with alcohol content is eating the rubber from the inside out. I'm looking fuel lines for the pumps that are resistant to alcohol but wondering if you Sweden guys who've been running longer than I (3 years) on E85 have had the same issue?
It's either the 30r10 if you want the flexibility of rubber or use hard line.
Submersible fuel line - SAE30R10
stocked at oreillys, carquest
A flash tuner, $350, would provide much more tuning ability but should be left in the car so the gas tune could be put back in if you switched back to straight gas. I leave my flash tuner in the car for that scenario even though I tune with hpt now.
Another way is some cars have an adjustable fuel pressure regulator. Just turn it up.
Hptuners has a Beta version with Cranking Spark tables for LS1 and LS2 ECMs. This will help get your car to start up like stock.
I'll play with it this weekend and update my progress. Right now it takes my car 2 to 3 cranks befor it fires up.
http://ethanolrfa.3cdn.net/dd9e74ce1..._rbm6bdgh3.pdf
pg. 31
"Octane: A minimum octane for E85 is not specified. FFV’s
can tolerate the lower octane of gasoline i.e. 87 (R+M)/2.
There is no requirement to post octane on an E85 dispenser.
If a retailer chooses to post octane, they should be aware that
the often cited 105 octane is incorrect. This number was
derived by using ethanol’s blending octane value in gasoline.
This is not the proper way to calculate the octane of E85.
Ethanol’s true octane value should be used to calculate E85’s
octane value. This results in an octane range of 94-96 (R+M)/
2. These calculations have been confirmed by actual octane
engine tests."
http://www.fuel-testers.com/gasoline...hanol_E10.html
I found this in the same article: "The addition of 10 v% ethanol will typically contribute 2.5
or more octane numbers to the finished blend." The #'s dont seem to add up...
