- Camaro and Firebird: What You Need to Know About E85 and Race Gas
Important information to help you understand your Camaro or Firebird.
Browse all: Chevrolet Camaro or Pontiac Firebird Fuel System Guides
How to run your LS1 on E85
I just did my 1998 Z28 automatic too this past Saturday the 17th
12.7x @ 110MPH on 93 gasoline, "bolt-on" car.
I'm on stock 28.8# injectors right now, & have tested all out, with no power problems.
Injector duty cycle of 118 on top, 6,200RPM ...
but AFR ok....Feels like 10-20 more HP. added 4 degrees everywhere.
On a full 1/4 mile pass I will be at 100 % + duty cycle for 1 second at the top of 1st gear, & 2 seconds at the top of 2nd gear, after looking at my log files...
I know that I shouldn't , but I did...
until my new 42# injectors come in on Wednesday...BUT, with the cooling effect of E85 Any stock 'bolt-on' LS1 should be able to get by with the stock 28.8# injectors, because how long are you really over 100%.....
100% duty cycle reached at 5,000 RPM.
I too have hard start/ cold idle issues that need addressed with cranking + cold idle tables.... anyone know which tables to change, & by how much....
Injector Pulewsidth(msec) * RPM / 1200 = Duty Cycle (in percent)
__________________
Chris
https://ls1tech.com/forums/fueling-injection/833273-injector-duty-cycle-explained-good-stuff.html
It's getting correct fueling as my WB readings are a-ok....
Got to take it to the track for testing....
Anyone know what the AFR needs to be for the 1st 30 seconds
after start-up...
It's my only issue......
Some start-up tables need changed, don't know which ones...
after start-up...
Look at the flex-trucks for a olfa that you can try out.
It runs so well during all my testing, that I 'm going to try it at the track with the stock injectors.
AFR at WOT is a-ok, new at over 100% duty cycle...
Same ET/MPH as the last time that I was there 12.7x@109.x
Weather, [DA], was worst. Track not preped as well...
I think it's at least a tenth better the 93 gasoline..
I'm really thinking about not changing out the stock injectors...
Got to check my 4 log files tommorow to see where it's at...
Bill
