- Camaro and Firebird: What You Need to Know About E85 and Race Gas
Important information to help you understand your Camaro or Firebird.
Browse all: Chevrolet Camaro or Pontiac Firebird Fuel System Guides
How to run your LS1 on E85
It should also be noted that the ethanol will do a super cleansing job on your fuel tank and fuel lines and you should change your fuel filter probably within a week of using this fuel to avoid clogging other parts. Your lines and tank will have a lot of varnish on them from years of using regular gasoline, the ethanol removes all that varnish.
I did test run my car on 100% E85 with stock injectors and had DC well over 100%
Just look at the Saab 9-5 Turbo with Biopower engine (big seller here in Sweden) that when it is fueled with E85 gives 20% more hp and 16% more torque compared with regular gas.
Yes E85 is perfect for boost
I have been doing alot of research on E-85 also. It is readily available here in Columbia, MO running around 1.50 +/- per gallon.
I have also done some forced induction testing with excellent results!
I will have LS1 Turbo results soon!
enjoy- to dispell some myths
http://www.rune85.com/internal%20engine.htm
posted by rubbersidedown in another thread.
