How hard it is to remove a gas tank?
Bill
If you have an aftermarket exhaust that unbolts easily, you may need to remove it.. And drop the panhard bar to get it out..
2 straps, and it angles out..
If its more then 1/4 full, its gonna be heavy!
I took the entire rear end out and still couldn't get the thing out. That is when I decided to bend it. Came out fairly easily then, however I had to bend it back after I put it back in, which was pretty difficult to do.
Just don't forget to remove the filler tube.
1. Remove exaust
2. Remove heatsheilding
3. Undo Feed/return/evap/power lines
4. Undo PHB
5. Undo gas cap
6. Heres the tricky part if its over 1/4 full you need a buddy. You undo the two straps holding the tank in and it wiggles out of there. If its a metal tank then your going to have move of a hard time getting the tank in and out beacouse the fillter neck is less flexible.
On a hoist is usualy 20-30mins depending on if the exaust is being fiesty. Never done it on jackstands but i would say about 45-60mins. Putting it back it might be easier if you dont put the gas into the new tank.
Might as well go ahead and do the Racetronix fuel system upgrade while you got that sucker down. There is always a win, sometimes you just have to look a little harder at the situation. Or just make lemonade out of the lemons life delivers you.
Thanks,
Bill
everything is self explanatory too. if not there is a picture floating around of how to do it
the hardest part is slipping the tank back in (need more than 1 person makes this easier) and making sure you don't crack all of those purty plastic wires/cables doodle things... lol
Bill
