Anyone sump there stock tank?
I need to **** or get off the pot with my fuel tank. I have been back and forth between a fuel cell and modifying my stock tank. In order to properly design a fuel system the biggest problem is fuel reserve in the tank. Originally I was going to install two -10AN fittings but without baffeling you risk the chance of pull air through the system. Stock tanks are not designed to pull fuel from anywhere but the center of the tank where the pickup and bucket is located. Based upon this I am leaning towards installing a sump kit and pulling the fuel from there. The other option was a large fuel cell but I would like to retain the stock fuel gauge.
Since I am upgrading to a 99+ PCM for custom OS purposes, I ended up picking up a later model gauge cluster and a 99+ plastic tank. 98 was the odd ball year for how the fuel is registered.
Any of you guys done the sump??
I spoke to the guys at Ricks Hotrod shop who makes a mean stealth tank that includes two Elimator pumps, filters, etc and is a bolt in............I just didn't like the price!
I plan to go with a sump AND keep my 1998 PCM. It pretty easy to do a sump yourself and not to mention, it looks badass. And if you cant do it yourself, Im very sure that it will be pretty cheap to have a shop do it compared to getting a custom pre-fabbed sumped tank, thats alot of $$$!
Originally Posted by Dwn Cam
May I ask what the price was for Ricks Hotrod Tank? I have a stock tank sumped with a comp engineering sump. I need to run a Eliminator pump as well, and I am a little worried that the stock tank even though sumped might not get the job done. Other options were the NASTY Tank and Ricks Hotrod Tank. I dunno?
Ricks Hot Rod wanted about $ 1200 for the tank with no pumps.
The fuel system we have designed will support 1600 hp forced induction. Twin A1000's out of a "sumped" area is a must.
We are converting our electronics over the 99+ so we can use custom OS's. We had obtained a 99+ cluster and plastic pump but it looks like we are going to need to find a way to keep the 99+ sensor with the 98 tank.
Originally Posted by 6techniques
In what way wouldnt the stock sumped tank "get the job done"?
Originally Posted by V6 Bird
Yes both outlets y;d together to feed that pump. Im running a Weldon 2025A off mine. No issues nor will I ever have any.
The Twin system sounds like an awsome idea, and a lot of headaches's.
