fuel pump inop
fuel pump inop
My buddy was driving his 99nbm (https://ls1tech.com/forums/vehicles-sale-lsx-powered-only/601340-1999-z28-370ci-th400-tea-heads-transbrake.html) and he hit a few bumps in the road, they weren't bad but they were successive bumps (in a row, about three) and the suspension is pretty stiff, so it jarred the car fairly bad, but nothing that out of the ordinary, and then about 5 seconds later the car revved a few times and died. It will crank over fine but not start now, and I noticed normally when you turned the key to accessory position before you start it, you can hear the fuel pump pressurizing the system, now, I don't hear anything. My first guess is the fuel pump is out, but before we get another pump and try to replace it I was wondering maybe if there are some wires or fuses that I should check?
Thanks,
Eric
Thanks,
Eric
