Moth balls in tank?
i heard that you can put moth ***** into your tank because its just like methane or methanol, something like that
is this true, and why would you do it if it is true
Mythbusters did that experiment. They said that it made that junker low compression caddy engine run better. This was not installed in a car and they just reved it w/o load. I would hardly call this a good test. I would NOT put them in my tank based on that.
If you put anything in your tank other than gas, make it 100 octane racing fuel and go very sparing on THAT unless you have a motor built for truly hardcore racing ... maybe 5 gallons or less to a tank of 92/93 octane and only when you're going to race because of the expense of race gas.
