installed 408 q on fuel system
Old Feb 20, 2007 | 09:07 PM
Slow00ls1T/a's Avatar
Default installed 408 q on fuel system
I just installed a 408 with the heads and cam in my sig
I know that they are killing me but how much power am i losing w staying on stock fuel system car hasnt been tuned as well
Old Feb 20, 2007 | 10:54 PM
DrkPhx's Avatar
What size injectors and fuel pump are you running?
Old Feb 21, 2007 | 09:57 AM
currently it is stock 26lb injectors w stock fuel pump i do have the racetronix pump waiting to go in
Old Feb 22, 2007 | 10:29 AM
any idea
Old Feb 22, 2007 | 02:08 PM
pushinfreight's Avatar
you will push the stock injecotrs with the 408. Most people go with a intank 255l wlabro and larger injectors when stepping up to a 408. 42lb injectors are pretty typical with a 408.
Old Feb 22, 2007 | 08:23 PM
Im hoping its fuel because it doesnt pull very hard up top
and i just barely beat a auto ls1 with headers exhaust lid and 3.73s
Old Feb 23, 2007 | 07:29 AM
sound like you need to have the tune looked at. A good 408 should beat a typical heads and cam. Now if you were at the track then that is another story.
Old Feb 23, 2007 | 07:38 AM
Rhino79's Avatar
You are probably seriously lean up top, I have tuned some bolt-on F-bodies that touched 90% IDC. On a 408 I tuned for a buddy, I put racetronix 38#ers in there, they will flow 43lbs at 58psi, and his runs 73% IDC at 6500 rpms.
Old Feb 23, 2007 | 08:28 AM
Ya im hoping that is the problem it was from a 45 roll
It feels like it has power until about 3500 then it just doesnt feel very fast at all
Old Feb 23, 2007 | 11:49 AM
Nasty N8's Avatar
You need fuel big time you can hurt the motor running it lean. Get the pump in and get some bigger injectors.
Nate
Old Feb 23, 2007 | 11:56 AM
TheCarKid's Avatar
Nate
you can definitely hurt the motor. it'll get too hot being so lean. hope you didn't run it in the high rpms for a long time. that motor is starving for fuel. pump and injectors ASAP!!
