Low pressure on Walbro?
Old Mar 12, 2007 | 08:22 AM
Speed's Avatar
Default Low pressure on Walbro?
Hey all. Just put together a dual intank setup using two Walbro GSS340s from EPP. Just a quick plug for Bob and his guys for making sure I got the parts in time.
Anyway, I'm having an issue in that one pump is only holding about 28psi at idle and dropping below 25psi on a load. The other pump runs great holding everything at factory 58psi at idle and upping a bit under load. Both pumps running at the same time also have idle psi at 58.
Wiring is correct and there are no leaks. I'm curious if anyone else has had this problem? Thank God I've got two of them
Old Mar 12, 2007 | 08:38 AM
Speed's Avatar
Sent an email to Bob at EPP this weekend and what do you know. First thing this morning I have an email back with a couple of ideas to check but more importantly, an offer to replace the pump. Even better, he said he would send a new pump out and when I swapped, I could send him the old one back. That's the way it's supposed to work! Thanks Bob
Old Mar 12, 2007 | 05:51 PM
john563's Avatar
Im having issues with my racetronics kit right now im waiting to see what they have to say.Im hoping they send me a new one and ill send the old,if they tell me to send this first and we'll get back to you im just gonna cut my losses and go look else where for a new set up.
Old Mar 13, 2007 | 07:15 PM
Racetronix's Avatar
LS1TECH Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
We have not received any support e-mails today in regards to a F98 or F99 system.
We do not supply warranty replacement pumps based on customer diagnosis. Over 90% of the time there is not a problem with the pump. It usually has something to do with the installation or operating conditions.
If you require tech support contact support@racetronix.com with as much info as possible along with all your contact info.
Thank you.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old Mar 13, 2007 | 11:24 PM
Speed's Avatar
I'll just say with one pump running fine and the other putting out low pressure through the same setup, I'm glad EPP doesn't have that policy. All the more props for Bob and the guys at EPP.
Old Mar 14, 2007 | 12:25 AM
Racetronix's Avatar
LS1TECH Sponsor
EPP's handling of your claim has been mirrored many times by Racetronix dealers so it is nothing out of the ordinary.
If retail vendors (including our dealers) chose to offer more flexible / liberal warranty policies to help secure sales that is understandable. This has nothing to do with a distributor's or manufacturer's warranty which is in place to serve as a guideline for warranty handling procedures.
__________________
>WEB SITE<
Old Mar 14, 2007 | 03:29 AM
koolaid_kid's Avatar
I am confused. To me, this sounds like lawyer talk. Have I missed something? EPP has earned its reputation for a quality dealer. Is Racetronix backing away from upholding its reputation?
Old Mar 14, 2007 | 09:26 AM
Racetronix's Avatar
LS1TECH Sponsor
Straight talk or lawyer talk call it what you will. Any reputable manufacture / distributor such as Racetronix will have clearly defined policies in place to deal with these issues in an unbiased and efficient nature. These policies should not vary with how much a customer has spent. Every customer deserves a fair shake regardless of who they are or what they have bought.
It is nice to see a customer happy with a reputable vendor's service such as EPP. Our original post was meant to address a question that had been posted by john563. It was not meant to compare or challenge services offered by other vendors such as EPP. There are 1000's of satisfied customers running Racetronix systems on this forum. We are sure EPP's customer satisfaction level is good as well.
John563 may contact support@racetronix.com for tech support.
Thank you.
__________________
>WEB SITE<
Old Mar 14, 2007 | 11:22 AM
I have not had any problems with my Racetronix kit. However, I will be certain to purchase any such items through a reputable dealer, rather than from the source. JMO.
Old Mar 28, 2007 | 07:53 PM
john563's Avatar
Thank you.
I have not heard from them,other than someone will get back to you and received another same exact E-mail,but ill try one more time
Old Mar 28, 2007 | 08:48 PM
Racetronix's Avatar
LS1TECH Sponsor
Isn't HSW providing customer-direct support here?
__________________
>WEB SITE<
Old Mar 28, 2007 | 09:58 PM
john563's Avatar
Yes he has sent me a new flex tube i just wanted to ask racetronix what else can cause the issues if the flex tube is not it.I have gone to the vendor and was very helpful and thought I'd ask Racetronix itself via e-mail.Im paying for install and yes they have installed them before without issues and for some reasone having problems with mine.I talked to Matt and he said it was the flex tube and gladly sent another,but just wanted to see if it could be anything else just incase.I explained the isssues to racetronix and got no reply as to wha t they think.Im not knocking anyone or product just want some trouble shooting info which Matt @ harris gave,but wanted some from Racetronix as well. Thanks you for your help
To the original poster im sorry to hijack,Ive started a new thread
