Leaded Racing fuel
Old Apr 12, 2007 | 02:08 AM
lsanb05's Avatar
Default Leaded Racing fuel
My buddy gave me 2 gallons of 120 octane leaded race fuel. I want to use it for one race. I have high flow cats out of long tubes on an 02 ss. Will this harm my car or make my o2's go out? Will 2 gallons really f*ck up my car?
Old Apr 12, 2007 | 05:53 AM
casper the ghost's Avatar
It will knock out your o2's and make them lazy.....
Old Apr 12, 2007 | 06:36 AM
brad8266's Avatar
When you take it to the track just put a junk pair of O2 sensors in so that your good ones dont get damaged. the O2 sensors arent used at WOT anyway so no performance issues will arise. once you get done at the track just put your good O2's back on.
What mods do you have that will require 120 anyway?
Old Apr 12, 2007 | 07:31 AM
bjamick's Avatar
Better mix it with 93 and the 120, and also im sure it will need to be tuned for that high of an octane fuel.
Do like 2 gallons of the 120 and like 3 gallons of 93 or something like that.
Old Apr 12, 2007 | 10:16 AM
12secSS's Avatar
Do not use it! Depending on what brand of 120 your are being offered, it most likely will burn a lot slower then the 91-93 pump gas. Adding higher octane fuel will only cause you to run slower, not faster. If anything, you can add ONE gallon of 100 unleaded to four gallons of 93 will give you just under 95 octane. Which for an LS1 is plenty. Adding those two gallons of 120 to 10 gallons of 93 will yeild about 98 octane, not worth the trouble.
Old Apr 12, 2007 | 12:13 PM
KONG's Avatar
FINALLY!!! Someone with common sense. No STREET car needs that ***** anyway!!
Old Apr 12, 2007 | 07:21 PM
383backinblack's Avatar
ya.....my car barely needs race fuel, we're just using it to be safe for the time being until we get it all sorted out lol......and only at the track
Old Apr 13, 2007 | 05:26 AM
Frost's Avatar
leaded fuel can melt the catalyst in your coverters.... should have been mentioned here
Old Apr 13, 2007 | 09:00 AM
KONG's Avatar
Are u using water or meth injection???
Old Apr 13, 2007 | 09:06 AM
KONG's Avatar
Most people probably dont know that little fact.
Old Apr 13, 2007 | 09:12 PM
lethal93ta's Avatar
I ran 110 in mine for a while but only due to having a supercharger running 10 lbs of boost on a 10.5:1 motor, I could advance my timing about 4 degrees with race fuel with out detanation, I got about 2 tenths out of mine, but thats just due to the detanation fact on a supercharged engine, most people dont need it, my new motor will be pump gas friendly with its 9.0:1 compression.
