good idea!
Old Feb 17, 2003 | 01:58 PM
smokinHawk's Avatar
Default Re: good idea!
David, so you finally got your second pump to come on and off at boost?
Any way my set up for now includes
42-svo's
walbro 340 intank
hks inline pump?
stock rails
stock lines
stock regulator
I think the regulator is my weak link as fuel pressure drops a little when the horsepower comes on. This is supporting 512rwhp so i need to better my fuel system before i make more increases.
I hope to mimic mightymouses set up <img border="0" alt="[worship]" title="" src="graemlins/gr_hail.gif" />
Old Feb 17, 2003 | 06:21 PM
MIGHTYMOUSE's Avatar
well i still dont have the boost yet, but the controller is all set up to turn on the second pump when it happens <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Feb 18, 2003 | 12:37 AM
Default good idea!
kind of separates bolt on guys in external from high hp guys <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> i hope im gonna be a high hp guys.. anyhow how bout everyone post their fuel system?
application : turbo
ford 42# injectors
cas boost/vaccum referenced fuel pressure regulator
stock tank, non sump
speed inc. aluminum fuel rails
speed inc. -8 bigazz fuel filter
two parallel walbro gss340 in tank.
single -8 braided feed to rail
single -6 merged to stock pressure line for return
russel fuel fittings and lines from jegs
ls1 edit to do the tuning
boost controller turns on the second pump. both pumps hotwired off of the accessory termial post to get full voltage w/30 amp fuses.
link: http://community.webshots.com/album/29211724vvFXlMScRb
injector upgrade soon as necessary
<small>[ February 17, 2003, 12:38 PM: Message edited by: MIGHTYMOUSE ]</small>
Old Feb 18, 2003 | 12:43 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Thanks but it was probably overdue and we should have added this forum a little sooner.
I'm gonna hold off on moving more threads until later since I made a number of changes.
Old Feb 18, 2003 | 01:59 AM
TanRchy's Avatar
very cool forum idea. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Old Feb 18, 2003 | 02:35 AM
AzzHauler's Avatar
From: Richmond, VA Where fast cars, well......are hard to come by.
My fuel setup is just like smokinHawk's, minus the inline pump. But you already knew that, didn't you David? <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
And I'm nowhere near maxing it out. <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" />
Old Feb 19, 2003 | 02:20 PM
sscamaro387's Avatar
OK, well..... I got a problem.
I m sure how to install all of that. Never really done a fuel system before.
But I got
42# inj
F/P reg.
Areomotive inline pump
Stock intank pump...... Trying to get a Walbro
Stock lines
Stock rails
So does anybody have a detailed(pictures etc..) way of putting a Walbro in?
Old Feb 19, 2003 | 02:51 PM
get with noyzee or rodent, i think they both have done plastic tank walbro pump installs.
Old Feb 19, 2003 | 03:01 PM
hey thanks
