'99 stock injectors good enough for Z06 swap?
Hi, I've done a search thru the archives, and read up on my stock '99 TA injectors and PSI. Im in the process up upgrading my LS1 to LS6 Z06 components (and then some). Im expecting the car to be around 400+ HP. My question is, are my stock injectors capable of supplying enough fuel for this swap (Im thinking not) and instead of changing injectors, can I simply up my fuel line pressure from 58 psi (stock I believe) to something higher to compensate. Or is it wiser to just by better injectors, like 30#ers and keep the stock PSI. I know I need to have the fuel tables re calibrated, and they will be, but until they are, will the car run ok...meaning from upper NY to NJ where it will be dyno-ed and tuned?
Do I need a better fuel pump(walbro?) and stock for 30# injectors?
Whats a good injetor brand also.
thx
DKL
<small>[ March 13, 2003, 03:16 PM: Message edited by: DarkLordFtT ]</small>
thx
DKL
