Fuel system for 600rwhp?
Formerly 4mulaJoe
Currently I'm running a h/c, 100 wet shot setup right now. I have the stock fuel system with a NOS inline pump. Well either the pump died or there is a problem with my wiring b/c it is silent now. I'm just going to yank it and get a good intank.
Once I think I've gotten all the potential out of this I plan on adding an extra stage maybe 75 shot.
Future plans could be bigger once this motor lets go.
I've been thinkin about a fuel cell for the nitrous runs, but I'm not sure how to work out the details such as mounting the cell and hooking up a pump and regulator to get the right pressure for my n20 jets. Also not sure what size line to run.
I'd really like to just drop a big intank that is a reasonable price and be done with it with stock lines.
So I only want to do this once and am on a budget. Recommendations?
Re: Fuel system for 600rwhp?
<img src="http://www.tamparacing.com/forums/attachment.php?s=&postid=460243" alt=" - " />
This was done with a Racetronix single intank with relay. Note the AF ratio...very rich...still have room for more.
I got a single intank 255L, 255 inline, and 42.5LB injectors, going to run 12psi through a 372c.i. motor...
Looking for 600rwhp + I should have enough fuel, but eventually, I'm going to do dual intanks and a big inline, bigger AN lines w/return, and bigger rails, and injectors...
383LQ4, I see you have a '99. Did Raceteronix get the '99-newer kits out, or are you using the '98 kit? I am and have been waiting for the kit to come out for my 2000.
Scott
Scott
DBL, wet kits spray fuel into the intake along with nitrous. Dry kits spray only nitrous through the MAF and allow the computer and fuel injectors to add the fuel.
