Alternative to the CAS boost referenced FPR?
LS1TECH Sponsor
Originally Posted by Black LS1 T/A
Cool... I may have to pick one up (even though I have the CAS regulator) as a backup. Nothin' lasts forever. About what PSI should it bee rated to? What type of AN fittings will be available? The CAS fittings were mis-matched to my Rail fittings.
Keep doin' ya thang, Racetronix.![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic3576_1.gif)
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
>WEB SITE<
LS1TECH Sponsor
I went to your site to check it out but didn't see any reference to a fuel regulator.
Jack
![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
Racetronix
__________________
>WEB SITE<
>WEB SITE<
LS1TECH Sponsor
Done! ![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
This regulator is available through authorized Racetronix dealers who support this forum!
__________________
>WEB SITE<
>WEB SITE<
There are pictures on the link in my sig. that show the Aeromotive installed next to the air box. The return line is on the drivers side next to the intake tube. You can see the Y from the fuel rails too. It is an adjustable regulator so I set my base at 52 lbs. which gives me plenty of room for the rising rate.
Moderator
52# base pressure is not enough for me. My base pressure is already about 62#. I won't know if I need that much until I get to the dyno. But, I feel better that I have extra headroom if needed.
LS1TECH Sponsor
Aeromotive regulators have consistent problems with regulation and their diaphragms.
Running a manifold referenced FPR will help extent the HP support range of your injectors as well as idle quality.
__________________
>WEB SITE<
>WEB SITE<
Wow, this is an old thread. Blown hawk was the name I was using to build my setup initially when no one really knew I had a blower and I wanted to keep it that way. ![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
Mike, what prompted you to dig this old thread up?
Interestingly enough I have noticed that my FP does have trouble maintaining a 1 to 1 relationship with my boost. It's mounted about 2 feet away from the rails. Is that too far away?
I might be interested in this FPR eventually. What PSI can it safely be taken up to?
Mike
Mike
