Walbro 255 Pump Problem
Old Jun 7, 2007 | 12:39 PM
bczee's Avatar
Default Walbro 255 Pump Problem
Has anyone had problems with their intank pump. After I have driven the car for a any amount of time and turn it off and then return to start it up again, it doesn't work or pump fuel. This doesn't happen all of the time.. but is happening more offen now.
The 1st time it happen, I had checked all of the electrical wire, ground, fuse and relay, I jumped the relay terms from power in/out to give the pump straight 12 and I didn't hear it working and still no pressure, I was bout to give up and call a tow trunk, (was at the last Pleasanton Good Guys, boy would that have been a good showing, being towed out !)
I had thought I was stuck and would need pull the tank and pump. But someone told me to bang on the tank to vibrate the tank and pump and sometimes will start... and sure enough it did. I have since rechecked the wiring and all.
The Tank is a 95 Impala tank with a Racetronix Walbro 255 pump in my LS1 converted Chevelle. I have a fuel pressure gauge on the fuel rail and using a 99' Vette Filter/regulator.
I am not sure if the pump is failing or there is something else wrong... It seem that the pump is freezing up and that by turning on the power and getting the pump to vibrate it will unfreeze and start working again..
Anyone ? Options ? suggestions ?
Old Jun 10, 2007 | 11:02 AM
Dave D's Avatar
Mine is acting weird also. I have a Walbro 340 LPH and it will run perfect for a couple of hours until it gets hot, then start bucking and barely running. It is only 2 years old also.
Old Jun 12, 2007 | 12:34 PM
bczee's Avatar
Well .. so far.. i thas only done this 3 time.. and banging seem to get it start everytime ... so far !..
