26lb to 28lb?
Old Jun 13, 2007 | 04:37 PM
1999ssls1's Avatar
Default 26lb to 28lb?
If going from 26lb to 28lb would I need a tune?
Old Jun 13, 2007 | 04:50 PM
WestSide's Avatar
yes, you'd run richer. but why would you take the time to swap them for 28s?
Old Jun 13, 2007 | 05:34 PM
1999ssls1's Avatar
I have the intake off and there free.
Old Jun 13, 2007 | 06:28 PM
1LoudTA's Avatar
and it really takes a whole 10 minutes, definitly get them tuned in though
Old Jun 13, 2007 | 07:45 PM
WestSide's Avatar
are these going on the setup in your sig? If so, those poor injectors are probably screaming! Double check all the orings!
Old Jun 13, 2007 | 07:47 PM
00PewterSS's Avatar
My car didn't drive any differently, but it already needed a tune. I was told the stock tuning could compensate for that small of an injector size change.
Brian
Old Jun 13, 2007 | 09:05 PM
1999ssls1's Avatar
Yes, these are going on with mods in sig. The injectors are probably screaming.
Old Jun 13, 2007 | 09:51 PM
sidewayz28's Avatar
id go larger then 28s
Old Jun 13, 2007 | 10:24 PM
ZL1Killa's Avatar
even though they may be free.... your gonna run out of injector. PERIOD. and i would hate for you to do all that work...and then BOOOOOOOOM , ooops 150% duty cycle and lean condition....
grab ya some 42#ers...they will do the soul good thats why i'm running
Old Jun 13, 2007 | 10:38 PM
WestSide's Avatar
Keep your stockers in there for now, save up, injectors should be next on your list if you can. Nice setup
I dunno if I'd hose it on either set of injectors...
Old Jun 13, 2007 | 11:18 PM
05 GSXR 1XXX's Avatar
yea lay low on those 26's....id hate to see your duty cycle with that 100 shot.
sell your 26's for 40$ and his 28's for 45$ and thats almost half of the price of used 42's lol
Old Jun 14, 2007 | 12:17 AM
sidewayz28's Avatar
u can do a cheaper method and buy some 39# injectors off an 03-04 cobra from svtp.com then buy adaptors.. and u basically have a great set of injectors for about $200...
Old Jun 14, 2007 | 01:32 AM
staringback05's Avatar
i got 28s with my ls6 manifold, the car was tuned for 26s...i didnt see any major difference for the month i had them before i got it retuned
Old Jun 14, 2007 | 05:43 AM
1999ssls1's Avatar
Thanks for all the input guys. Thing is, I havent even got to work this month. Meaning no money and that means all the money I have is for bills and lord knows I have enough of them. So I am going the cheap route for the moment. They have to be better than my 26s for now. Right?
Old Jun 14, 2007 | 06:06 AM
WestSide's Avatar
You won't notice a difference really, lay off the spray and you should be ok until you can afford some bigger injectors. Just trying to look out for you man, hope the job situation works out
Old Jun 14, 2007 | 06:22 AM
1999ssls1's Avatar
You and me both on the job. It wouldnt be that bad I just tore my tranny out and have to pay for it today and all kinds of other crap. Im not really doing the injector change for performance. The car seems like it runs lean up top and I just now got around to changing intakes, so I thought it would be a good time to change injectors. Thanks for your help and concerns.
Old Jun 18, 2007 | 11:31 AM
StngKlr's Avatar
The duty cycle wont look any different on/off the spray.
Old Jun 18, 2007 | 12:01 PM
ZL1Killa's Avatar
depends if its wet or dry doesn't it? (i've never played with nitrous soo yeh)
Old Jun 18, 2007 | 02:14 PM
1999ssls1's Avatar
It would look different on a dry shot.
Old Jun 19, 2007 | 05:00 AM
StngKlr's Avatar
This is correct. But your sig. clearly states that it is a wet shot. You still need a good functioning fuel system though. But for the rest of your problems, I'd change to the 28's and see if they help any, then go from there.
