LS1 vs. 3.8L fuel pump and lines
Old 06-15-2007 | 12:54 AM
01CaMMMaro's Avatar
Default LS1 vs. 3.8L fuel pump and lines
im looking into dropping an LS1 into my 01 camaro. I know i know i know, "you should just sell your car and get a LS1 car." But, this was a project my dad and i wanted to do but he passed away a few months ago so id really like to do it. my question is... I know i need a new fuel pump for the new engine because of the PSI difference. Are the fuel lines different from a 3.8 to a LS1? it is an 01 camaro.
Old 06-16-2007 | 11:30 PM
01CaMMMaro's Avatar
ttt...
Old 06-17-2007 | 08:25 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
The 3.8 does not have a tank mounted regulator so you will need to make some changes to the fuel system.
Old 06-17-2007 | 11:54 PM
01CaMMMaro's Avatar
can i reuse any of the lines?
Old 06-20-2007 | 05:29 PM
blackbyrd's Avatar
im doing the same swap so if you have any other questions go ahead.
and isnt the ls1's fuel regulator on the rail??
as far as lines i was told you would need to switch
it has somethign to do with the v6 having or not haveing a return line (its one or the other is the reason you need the ls1 lines) and a friend of mine is selling the lines off of his actually should you be interested.
Old 06-20-2007 | 05:31 PM
blackbyrd's Avatar
dont know how much you have looked into it but i will pm you a great place for parts as well as info on the swap as far as what will work and parts needed
Quick Reply: LS1 vs. 3.8L fuel pump and lines
