Installed my fuel pump (trap door): DO NOT buy RACETRONIX's fuel pump kits...
Originally Posted by DEMONBIRD
Unless you want to buy the best d@mn fuel pump kit out there
I know it has been posted a bunch so I figured I'd mix it up a little... It is SO TRUE THOUGH!
HANDS DOWN THEIR KIT IS THE BEST AND MOST THOROUGH INSTALL KIT OF ANY PRODUCT THAT I HAVE EVER SEEN!!!
These guys really took their time putting these kits together, getting everything you would need and making extremely detailed instructions.
I just installed their pump on my 1998 Z and will do the harness tommorrow (it is 5:00am after all)... I went the trap door method but the actual time required to hook the pump up was under 15 minutes... Seriously, they thought of everything
I know people like pics but the only pic I have is of the plate I made to install over the whole I cut. It is metal that I put vinyl stickers on, sprayed the whole thing black, removed the stickers and then clear coated it:
![](http://i31.photobucket.com/albums/c362/markdelisle/Fuel%20Pump/FuelPumpPanel19.jpg)
Not the best pic but you get the idea...![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Anyways, I HIGHLY recommend their kits (the pump housing looks so friggin cool it's a shame no one will see it) and their directions are second to known![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
to me the hardest part was finding a good spot to mount the fuse that was on the wiring harness.
