Need help with building a fuel system for my setup
The car already has heads and cam kit pushing 440rwhp 390rwtq
i just ordered the APS twin turbo kit. i wanna be able to run about 7-8psi on pump 93 and turn it up to 10psi with meth. what set up should i run what injectors and fuel pump will support this i'm figuring around 600-650 rwhp.
i would like to have a fuel system that i can add to in the future when i build my 408ci and just change injectors.
what do you guys think?
Give me a call, I can set you up with everything you need.
The time when I am most able to discuss this in deatil is:
7:00pm-11:00pm eastern time weekdays
& 9:00am-11:00pm weekends.
at (724)322-8505
If you don't want to piece together the system yourself, there are a few sponsors here who have kits. But it isn't hard to put everything together, just takes a bit of time and research
Peter
http://www.airpowersystems.com/guide...-fss01/bom.htm
http://www.airpowersystems.com/fbody...sgmf-fss01.htm
two relays to run the pumps = $12
mototron 60# injectors = $400
stock lines are fine for that range, i personally wouldnt run both pumps all the time but some do it w/out consequence
I was curious as to how much the APS DP setup was. Or @ Least a link to more info. on pricing.
