Belt driven fuel pump
Old Dec 19, 2007 | 04:19 PM
  #41
Bracket Boy's Avatar
Phil,
The cold startup is working well and as soon as it sees any fuel pressure it will try to start. I might crank on it 10 seconds when it's cold before it will try to start and it's 45-50 degree's in my garage. I am not using a gear reduction style starter in an effort to keep the cranking rpms higher also. I am having issues now with the restart tune once the engine has a little heat in it. Trying to work through it as the EFI is all new to me.
J.
Old Dec 19, 2007 | 04:28 PM
  #42
Phil99vette's Avatar
7 Second Club
Bracket Boy,
What computer are you using?
Phil
Old Dec 19, 2007 | 10:10 PM
  #43
Classic FAST is what I have right now.....
Old Dec 27, 2007 | 09:39 PM
  #44
barnat's Avatar
Default belt driven!!
Originally Posted by Lason
Multiple reasons. Mainly because I dont want to have to worry about my fuel system later on if I turn the boost up. Also I hate loud pumps, and am tired of having them burn up, pop fuses, etc etc. I can run a belt driven pump for a few bucks more initially and never have to worry about the noise, having it burn up or anything. Only problems would be possible belt being thrown and initial starting if the car sits for a few weeks.
This is going in a tubbed out '73 Datsun with a turbo LS1, glide.
Dude,Me and you think alike!LOL!Check out my belt driven scavanging pump that we made to replace the electric, under the FI section (Belt driven scavanging pump)You could mount just like I did!!Check it out !
Old Jan 5, 2008 | 12:53 PM
  #45
camarols1's Avatar
I just got my Aeromotive pump and I came up with an interesting mounting idea.
Since the LSx engines don't have mounting holes where the pump needs to go, on the block, I needed to come up with an easy to fabricate solution.
I mocked up an a/c bracket off a 6.0 truck application which mounts low on the passenger side of the engine.
As it turns out, the two bolts on the front of the a/c bracket for the factory belt tensioner line up perfectly with the Aeromotive pump bracket.
All I need to do is clearance the bracket to clear my conversion motor mounts and space the pump out as needed.
I will try to post up some pics this weekend.
Old Jan 6, 2008 | 12:28 PM
  #46
camarols1's Avatar
Ok, here is what I have done so far in about 20 minutes.
I had to trim the truck a/c compressor bracket to clear the Ats engine mount plates and also the frame.
The Aeromotive pump bracket lines up perfectly with the two threaded bolt
holes on the front of the a/c compressor bracket.
I may need to make adjustments to allow for more belt tension adjustment,
but I could add an idler pretty easy if needed.
I need to have the center of the mandrel turned down a little to slip inside the ATI balancer, and I will need to make some spacers to move the pump about two inches further forward to create more room for the fuel lines.
I think this is a good start considering how little time it took to do this.
This was the only mounting solution I could think of that allowed me to mount the pump low enough to ensure good priming on the street.
Let me know what you think!
Attached Thumbnails Belt driven fuel pump-p1010099.jpg   Belt driven fuel pump-p1010107.jpg   Belt driven fuel pump-p1010111.jpg   Belt driven fuel pump-p1010113.jpg
Old Jan 7, 2008 | 01:05 AM
  #47
ls1408cp's Avatar
thanks for the update. Did you buy the kit they sell in summit that includes everything? So it will work with that pulley if trimed down? Do you have part numbers that would be great. thanks
Old Jan 7, 2008 | 08:51 AM
  #48
camarols1's Avatar
I picked up the pump used, but I will try to get the part numbers from Aeromotive today.
Basically, this is the standard #11105 belt pump, with their Big Block Chevy specific mounting bracket and drive mandrel.
The #17140 universal pump kit includes a straight style mounting bracket which will not work with my setup.
The mandrel will have to be turned down a bit to fit inside the balancer.
Edit...
The current #17140 pump kits are now built using this style bracket, per Aeromotive.
Old Jan 10, 2008 | 02:36 PM
  #49
lowdeuce's Avatar
Very interested to see how this turns out. I have been debating on running a belt drive or a Prostar 500 for my carbed 6 liter.
Jared
Old Oct 9, 2008 | 04:47 PM
  #50
TT402LS1's Avatar
Any updates on this? Im looking to do the same with my project. Im doing it for the same reasons as camarols1. If it is as streetable as Aeromotive claims, and I can find a place to mount it, I will probally got for it.
Ron
Old Oct 9, 2008 | 04:51 PM
  #51
Juiced's Avatar
I have mount that will bolt to either the front of the alternator bracket is you are running a f-body setup, or to the block if using a vette setup. i had it on my car and it worked great.
Old Oct 10, 2008 | 05:41 AM
  #52
TT402LS1's Avatar
Im running a S&P front assy drive setup. I would probally have to make my own braket. I love to fab things! What size pully do I need for the balancer?
Ron
Old May 6, 2011 | 04:23 PM
  #53
FakeSnake's Avatar
holy resurected thread batman, any one else using a belt driven pump? can you post some pics and part numbers please
Old May 9, 2011 | 06:05 PM
  #54
kmracer's Avatar
Originally Posted by DuronClocker
Yeah, after being incredibly lean under high load and high RPMs. That sounds good for the motor, especially if spraying or boosting
is that as bad as or worse when one fuel pump dies? or voltage drops? or a fuse pops? or a relay burns up? or a motor burns up?
if you look at the design of the pulley, its pretty tough for the belt to fly off, and theres alot less to go wrong on a BD pump.
Old May 10, 2011 | 05:41 PM
  #55
charleysheen's Avatar
good dead thread bump, lol
i was wondering the same thing though
Old May 21, 2011 | 02:41 PM
  #56
FakeSnake's Avatar
surely someone else is running one of these that can post some more pics...
Old May 21, 2011 | 04:10 PM
  #57
jasond26's Avatar
I just got mine mounted up today I will get some pics of it. I have a little more fab work to do for the adjuster but it is very sturdy so I hope it holds up well to rpms.
Old May 26, 2011 | 09:39 PM
  #58
jasond26's Avatar
here are the pics of my mount. I need to add the adjuster bolt but I am waiting to get the mandrel and pulley to finish that.
Attached Thumbnails Belt driven fuel pump-engine-pics-004.jpg   Belt driven fuel pump-engine-pics-005.jpg
Old May 27, 2011 | 01:07 AM
  #59
Blown06's Avatar
8 Second Truck Club
Jason,
What are you doing for the fuel cell? Up front or rear?
Old May 27, 2011 | 08:41 AM
  #60
jasond26's Avatar
rear mounted. The pump is mounted lower than the cell and I am running -12 to the pump so there should not be any issues. I have researched a bit and people only run into problems when they start getting into the 1.1 60' range. I don't think I will ever be seeing that...lol.
