Can you kink / break fuel line?
Doing a FAST 90 swap and couldn't disconnect the feed line to the rail system. Took the manifold off and twisted the feed line. It appears to be a hard plastic line covered by a rubber line. Can twisting break or kink the line?
Do I need to replace?
Appreciate any input.
![Huh](https://ls1tech.com/forums/images/smilies/LS1Tech/huh.gif)
any auto store should have fuel line disconnect kits. There cheap. Don't know if that helps, if you already got it off and are worried about using it, I would think that unless you can see some physical damage it should be ok.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Yes, twisting CAN break/damage the fuel line.
Originally Posted by myfast70
Why not just disconnect the fuel line from the chassis and use an adapter to convert it to a -6 line?
![The Pimp](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_pimp.gif)
