racetronix prolem
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
>WEB SITE<
I assume you're testing for power with the Ignition in the ON position (engine off). The block you are referring to supplies power to the fuel pump and rear ABS, so if it was bad you wouldn't have power for that circuit as well. Anyway, try swapping back the stock plug n play wiring harness that connects between block and fuel pump.
If that doesn't fix the problem, check the inside of the female connector for the power (grey or orange?). Over time they spread apart and will not form a solid connection with the male pin on the body mounted block. A dead giveaway to this problem is carbon (looks like soot) located on the pin caused by arcing. You need to tighten up the metal tabs on the inside of the pin for a solid connection.
Important: You must use the the little "lock tab" that slides between the harness and block. Otherwise road noise and vibrations will cause it to back out and lose connection resulting in power loss.
The factory rear connector isn't recieveing power because of the other relay located under the hood. This relay recieves power but for some reason doesn't switch the power out to the rear of the car. If you jumper this relay under the hood everything works perfectly fine, even going through the racetronix relay.
My conclusion would then be to check my pcm connections and see if any of them are loose or corroded resulting in not allowing the underhood relay to switch power over.
Only thing that sucks is I have to leave for work now so I won't even be able to make sure thats the problem until later this evening
Hopefully thats it and the car will be running later on tonight.
What wire, factory wire or a Racetronix wire?
I finally got to work on the car today and simply installed a new crimper on the old wire and tightened the grounds back down on the head. The car got full power to the pump so I continued to put it back the way it was. Drove a couple of miles and the car drives excellent. A big thanks goes out to my g/f who helped me get those damn fuel lines back onto the pump housing, she helped out a lot. Good to be tearing it up again before winter
Thanks to everyone who helped.
