racetronix prolem
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
If it does not work then you have a factory wiring issue.
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Nate
Unplug the RX harness and plug the factory harness back into the bulkhead connector. This will allow you to run the pump off of the factory wiring to make sure it works.
>WEB SITE<
Plug the Racetronix harness back in and then jumper pins 30 and 87 on the relay socket with a piece of wire. The pump should run assuming the RX 20 amp fuse is OK. You can ID the relay terminal numbers by looking at the bottom of the relay. These are the terminals with the thick red wires going in. If the pump still does not run you have a problem either with the factory wiring or pump assembly.
We can send you the GM diagnostic procedure if you do not own a factory service manual.
>WEB SITE<
>WEB SITE<
>WEB SITE<
