416 ci., 13 to 1 compression, naturally aspirated race engine, what size injectors?
Originally Posted by Dragaholic
I used to have a set of SVO 30s, which at our fuel pressure would be 36 lbs. I figured they weren't going to be enough so I sold them.
good move-
42 will be more than enough-will even support more if u want to do more mods in n/a trim
what power u looking at with that comp ratio-it should be good-
I used to run the green top 42's (About 49.7lbs/hr at 58psi fuel pressure) on my 13:1 417ci, with the top-end power robbing lsx I made 504rwhp sae through about the same drivetrain (th350, no l/u, 9", 35 spline axles, 4.11s, 30x10.5 radial slicks). I was running in the 83% IDC range. Now I don't have injectors anymore
