hard start after walbro....
Old Sep 29, 2007 | 03:49 AM
daniel6718's Avatar
Default hard start after walbro....
ok goana try and make this quick...had trouble keeping over 30 psi fuel pressure in my car..95 z...changed filter, regulator, made sure no leaky injectors, then sprung for a new racetronix kit...got it installed it and right away 55 psi at prime and 48 or so when it started...car drives like a champ ect much more power......but now it hard starts bad...i hooked up a gauge and you can prime the pump and it shoots for 55 psi, once the pumps done priming it drops to 5 psi within 3 seconds...its not a leaking fuel line and its not a leaky injector i checked....so it has to be leaking on the feed line inside the tank right?
i posted on another site and was told by some1 that
""There's a check valve in the pump that holds the fuel pressure in the supply line. May have failed already. Or you may have a loose hose at the pump.""
im going to check tomaro about the hose but i think if the hose was loose it would have blown off the line already....
i bought this brand new unopened from another member off here...he got it from thunder...who can i call?
Old Sep 29, 2007 | 10:16 AM
BigJls1's Avatar
This happens alot. dont get pissed but there is probally a hose clamp loose. You will probally say " no way everything is tight and looks good". But I am telling you alot of folks have some issues with the walbro and 9 out 10 times its a losse wire or hose clamp.
My car has a walbro with out the check valve. starts fine. no differnt than factory.
Old Sep 29, 2007 | 12:18 PM
daniel6718's Avatar
yea i would agree with you but the new walbros have a clip that they clip on now so your hose clamps cant be loose...
Old Sep 29, 2007 | 03:04 PM
BigJls1's Avatar
hmmmmmm. I know.
When your car sits over night will it fire right up? but if drove to a store and did some shopping, came out and it cranks for a long time to start. It this is happening it is your fuel pressure regulator. they are less than $100.
Old Sep 29, 2007 | 05:06 PM
daniel6718's Avatar
it hard starts all the time...you have to prime it to get pressure first...15 seconds or a day...
ive got 3 differant stock regulators i can try another but i know this ones good i just pulled it off another car....
Old Sep 30, 2007 | 02:08 AM
daniel6718's Avatar
anyone else got an idea on this hard start? is the check valve bad or is there supposed to be a clamp on the pressure line? i got the new version and it clips to the feed line....
Old Sep 30, 2007 | 09:51 AM
BigJls1's Avatar
Got me stumped.
Old Sep 30, 2007 | 11:31 AM
Thule's Avatar
what is the lt1 orginal fuel pressure? isn't 55psi kinda low for walbro pump?
Old Sep 30, 2007 | 12:34 PM
Racetronix's Avatar
LS1TECH Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
In most cases this is because the fuel tube is not sealing properly. Usually this happens because:
- the gear clamp is over tightened
and/or
- the plastic ribbed outlet has been scored deeply when removing the factory fuel tube
It is possible for the regulator or a leaky injector to cause this problem as well. Your GM factory manual has a step by step diagnostic procedure to help isolate this type of problem.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old Sep 30, 2007 | 01:44 PM
daniel6718's Avatar
well can i put a hose clamp on the new style ribbed line? theres no scores in it i made sure to be careful because believe me i dont wanna be doing this again...i checked fro leaky injectors...but i have no clue how to check for a leaky regulator??
dont have a service manual....
Old Oct 1, 2007 | 11:24 PM
daniel6718's Avatar
anyoner familiar with the new pump and ribbed hose that now clips onto the pressure line
