Twin Turbo Truck Dual 255 pumps
well guys im trying to wire the second pump together with the original harness.. but with an extra relay for the second pump.. or i was also thinking if i should just wire it with a micro switch that way the second pump only runs at full throttle???.. please let me know ya'lls opinions.. thank you
so you just wired them together??? or you added a switched 12volt supply for the 2nd pump?.. also i think im just gonna go with a hobbs switch that way the second pump turns on at 8lbs of boost.
