racetronix kit
Old Oct 31, 2007 | 12:10 PM
daniel6718's Avatar
Default racetronix kit
1995 z28
well my pump wouldent hold but 25 psi 27 with the vac line off
so i got a pnp kit new and installed it...running the car has 47 or so...and 42 with a simple prime...problm now is that when it was first installed it bled off quickly...it went to 0 almost instantanous...havent had a free day to mess with it in a while but it got better it was hard starting BAD....now its ok but still crank about 2 seconds to start sometimes longer..so today i put a gauge on it and its the same except when i turn it off now it SLOWLY bleads over about 1 minute from 42 to 2 or so...ive checked for leaky injectors...i also removed the return line as a friend primed it and right after it finished priming i removed it quickly and nothing came out at all...helt my finger there and still nothing...so it has to be leaking back into the tank...
i dont think its the connector on the end of the wabro ribbed line because its a newer design (from about 2 years ago when i got my last one) now its a slip, used to be use a clamp...i think its the walbro itsself...anyone else got ideas? or reccomendations?
Old Oct 31, 2007 | 04:56 PM
daniel6718's Avatar
its actually 43 with the line on and 47 with the line off...give or take 2-3...
and i specifically stated above that i checked for leaky injectors and leaky regulator both are fine...
Old Oct 31, 2007 | 06:03 PM
daniel6718's Avatar
wtf happened to his post?
Old Nov 1, 2007 | 03:11 PM
daniel6718's Avatar
tttttt
Old Nov 1, 2007 | 04:20 PM
TAwhore's Avatar
check your scrader valve?
Old Nov 1, 2007 | 05:28 PM
cpd004's Avatar
I thought that was a common problem and may be the check ball in he pump. Try searching and you should turn up something.
Old Nov 2, 2007 | 12:08 AM
daniel6718's Avatar
wheres the schrader valve goana leak to when im pressure testing it with a gauge connected to it?
Old Nov 2, 2007 | 12:22 AM
daniel6718's Avatar
well i like togive walbro the benefit of the doubt...ivee had 2 of their pumps before with no problems...i have no clue why this one would have a problem...
is there a way to safely test this? like putting pump in a bucket of gas and letting it pump then bleed off? ect? who can i call racetronix/nasty?
Old Nov 2, 2007 | 08:51 AM
cpd004's Avatar
I too have had problems and several that worked perfectly for years. Did you search at all??
https://ls1tech.com/forums/showthrea...ix#post3858716
https://ls1tech.com/forums/showthrea...ix#post5318542
Old Nov 2, 2007 | 10:59 AM
daniel6718's Avatar
yes i searched but i HATE the new search..hard to find anything on it
Old Nov 2, 2007 | 11:04 AM
daniel6718's Avatar
man not only did i buy a new pump and install it but if i wana fix the problem its goana be out of my pocket...this sux...wouldent mind if it was a toy or street strip...but my daily i wanted to be perfect...i removed the tank and everything...now i gota do all this **** again after buying a new pump!
im goana put the stocker back in a see what it does...ill post back when i see if it bleeds off
