help w/ fuel injectors
Old Nov 1, 2007 | 09:35 AM
3rdgentug's Avatar
Default help w/ fuel injectors
im fixing to have to buy new fuel inj since im doing a head/ cam swap
should put me in the 430 - 450 rwhp range, i know i need to upgrade my fuel pump as well, thats easy. i need to know what injectors size i need.
i used the sticky and based lined it at:
bhp= 525
( figured that might be close )
8 injs
47 psi fuel pressure
and came up w/ 39.46
so rd up to the 42 pd injs would be my guess
please help if my maths off here somewhere i tried my best n used the searches and stickys
Old Nov 1, 2007 | 09:59 AM
Nasty N8's Avatar
32-36 will be plenty but if you want lots of room to grow 42 will work as well.
Nate
Old Nov 1, 2007 | 01:07 PM
3rdgentug's Avatar
tx n8
i was looking at the 42pd inj harris is selling new for like 275$ shipped
i see svo red tops which i know are good going for like 175- 200 used that are the 30# which if memory serves act like 36# on our systems
Old Nov 2, 2007 | 08:52 AM
3rdgentug's Avatar
does anyone know if that last statement i made is correct
svo red tops that are 30# act like 36# on our systems and should be enuff for my application?
Old Nov 3, 2007 | 02:12 PM
3rdgentug's Avatar
bump up
Old Nov 3, 2007 | 03:45 PM
koolaid_kid's Avatar
Go with the Racetronix/Delphi/Lucas 42# injectors and be done with it. The worst thing you can do is to get just enough injector, and then need larger ones when you make other changes. You can tune a larger injector down to work just fine, and the difference in price should not be that important when making the initial purchase. Do it right the first time, and do it once.
Old Nov 3, 2007 | 05:20 PM
RareBreed0295's Avatar
42# injectors should work good for your setup
Old Nov 5, 2007 | 08:51 AM
3rdgentug's Avatar
thx im gettin the racetronic 42# from harris since they are on sale
Old Nov 5, 2007 | 11:34 AM
Same place im getting mine from. They got a good sale going on now.
