NEW Racetronix 79LB/HR HIGH IMPEDANCE FLOW-MATCHED INJECTORS
#63
racetronix sponsor. you need to help me out here. explain why i need those injectors. explain how this whole low impedence thing works. and explain why no one has 120 high impedence injectors. i like your guys stuff. but need answers
#64
Your OEM PCM has injector outputs that are matched to what is known as high-impedence or High Z injectors. As they become physically larger, their internals do as well, and they need more power to cycle. Low impedence injectors fills this void. Your stock PCM cannot supply the current for them without a driver box. As of right now, these are about as big as you can get staying high-Z.
#66
Anyone put these in their car yet? I'm waiting to buy them, I just want to see how tuning and idle quality go. Its the last item to buy for my shopping list, then im ready for install.
#68
Im about to run out of injector this weekend. It would be nice to get some test's. How about hooking me up with some Jack, At a tester price
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
#72
Well I finally got everything going. Here is a log of the 79# injectors, it's in EFILive. The afr will be off since i am using E-85 and have a custom Pid for my LM1. They are running real lean, not sure why, but it leaves the idle a bit choppy.
#75
It just dawned on me, part of the problem may be my intake, it got so cold here that some of the areas where the bolts go through cracked. I wont know until I get a stock throttle body and put on the stock intake.
#76
It would seem that they are not as efficient as the 42's I had. I had to add 25% then another 25% to the voltage adjust table at idle. And lots of adjustment all over the table. Now I just need to get the idle under control, it's way to high. And acording to my math, with the altitude adjustment then the E-85 increase, I am using only 4% more fuel then someone at sea level.
#77
I'm very interested in what you are doing. I want to try running e85 some day. I just don't want to give up the driveability I have now with the mototron 60's. I am already maxing them out on my racegas tune.
Keep posting your results! Are you going to up the boost & see what you can get out of these injectors?
I will be in your area this summer with my car.
#78
#79
