NEW Racetronix 79LB/HR HIGH IMPEDANCE FLOW-MATCHED INJECTORS
Old 02-17-2008, 06:17 PM
  #81
shizon's Avatar
Trying to decide on this or a driver/low z setup for around 800rwhp on e85/boost. By the calcs, it looks like it would be pretty close.
I know others have mentioned this, but if there's a trial set, I'll put them in and get video on gas and e85 under boost.
Old 02-22-2008, 11:55 AM
  #82
ls1408cp's Avatar
So do these flow more the 60s anyone go from 60s to 79s to compare
Old 02-25-2008, 12:35 AM
  #83
LS1TECH Sponsor
Racetronix's Avatar
If your calcs push the DC much above 80-85% then you should consider a low-z higher flowing injector.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old 02-25-2008, 12:48 AM
  #84
JMBLOWNWS6's Avatar
LOL No one has tried these yet? Dammit I need a test dummy deal!
Old 02-25-2008, 06:25 AM
  #85
cablebandit's Avatar
for the price you can buy a impedance converter box and some 96# injectors. They idle fine in my car
Old 02-25-2008, 08:08 PM
  #86
JMBLOWNWS6's Avatar
I allready bought the imp box and 96'ers.
Old 02-25-2008, 09:39 PM
  #87
SuperZ's Avatar
Im going to order some in the next week or so but I wish we had some results from someone first!
Old 02-26-2008, 06:39 AM
  #88
ZL1Killa's Avatar
OMG people... ok the 43.5psi @79lb/hr equalling 91lb/hr @ 58psi has been explained. these will support HP up to :
** THESE ARE ESTIMATES AS ACTUAL REAL WORLD TESTING WILL RESULT DIFFERENTLY. THIS IS ALSO ASSUMING A MAX DUTY CYCLE OF 80%
1000 BHP @ 43.5psi FUEL PRESSURE N/A
and 1150 BHP @ 58psi FUEL PRESSURE N/A
BOOSTED:
800 BHP @43.5psi BOOSTED
1060 BHP @58psi BOOSTED
and this is all thanks to
http://www.rceng.com/technical.aspx?...fJ2V9FMSlGw2H8
provided by my link under this section (fuel and injection)
Old 02-29-2008, 02:04 PM
  #89
SuperZ's Avatar
Ok I just ordered a set.Ill have feed back in a few weeks.The setup will be a stage 3 street nastys fuel system and a 402 with S91.
Old 04-19-2008, 01:52 PM
  #90
b727pic's Avatar
any updates on these....idle tuning etc....
Old 04-19-2008, 03:34 PM
  #91
OneMean01's Avatar
I know SuperZ is fixing to get his tuned really soon, I believe in less then a month. I'm just waiting to see what his tuner says on them then i will decide if i buy them or do something else.
Old 04-19-2008, 05:44 PM
  #92
Robert56's Avatar
Subscribing and waiting. I would like to try these with my new Dry Direct port set-up and a proposed 350rwhp shot. I would like to be able to do all my tuning with the stock PCM.
Robert
Old 05-12-2008, 06:45 PM
  #93
7 Second Club
10sec_rx7's Avatar
yes done it and they work fine,
i replaced a driver box and 96lb injectors with these and they work a lot better and still flow enough for close to 1250hp
we were making 1100hp at around 80% duty 160mph at 3350lbs tells the story there
the driver box seemed to send funny signals to the injectors and we were getting up to 200deg C difference between cylinders.. the car still made power and did everything it needed to, you wouldnt know there was something not right unless you have a temp setup on each cylinder.
i just need racetronix to do a 120lb/h high Z injector now and ill be set for the new setup
Old 05-13-2008, 04:59 PM
  #94
TAQuickness's Avatar
What's your fuel pressure for that setup?
Old 05-13-2008, 05:10 PM
  #95
99.9percenter's Avatar
Best news I've heard all year!
Old 05-13-2008, 06:14 PM
  #96
7 Second Club
10sec_rx7's Avatar
60psi static plus boost pressure
Old 05-13-2008, 08:10 PM
  #97
What's the small pulse thresh hold (i.e. SVO42 at 61psi base pressure requires > 1.79x ms to get a squirt)
Old 05-14-2008, 06:33 PM
  #98
stevieturbo's Avatar
Why not just run a pair of 60lb's per cylinder then ?? Id hazard a guess the factory injector driver could cope just fine with a pair of injectors wired in parallel.
Old 05-14-2008, 06:37 PM
  #99
7 Second Club
10sec_rx7's Avatar
im going to be testing the 2 injectors per driver very shortly on my daily driver before we do it on the race car, if that is the case and it does work i will run the 79's and a set of stock injectors just to get it over the line,
Old 05-14-2008, 06:44 PM
  #100
I wonder does anyone have any info, on how much current the drivers can actually handle ??
I do not run a factory ecu on my car. But it can easily handle 1, or 2 injectors per driver. In fact...I know people who have wired 4 injectors per driver in some cases with no problems.
Quick Reply: NEW Racetronix 79LB/HR HIGH IMPEDANCE FLOW-MATCHED INJECTORS
