-Fuel System for Boost-
Old Nov 10, 2007 | 01:59 AM
my01ws6's Avatar
Default -Fuel System for Boost-
Ok basically I need some help with getting my fuel system together from my procharger set up.
I will be running a P1SC on like 6-8lbs of boost. Basically I want a fuel system that will let me max out a P1SC....so like 650whp capable. I will be only running like 460-500whp for awhile till I can afford to forge my bottom end.
I was thinking 255 intank, 42lb injectors, speed inc high flow fuel rails, aeromotive FPR.
What brand pump and injectors should I go with? Should I go to like a 55lb or 60lb injectors to meet my goals?
ALSO VERY STUPID QUESTION PROBABLY....when changing to 42lb injectors will my gas mileage decrease? if I go to a bigger injector like 60 will it decrease even more?
Thanks!!!
Old Nov 10, 2007 | 08:30 AM
BlkHwk's Avatar
Changing the injectors will not affect your fuel economy as long as they are tuned for your setup. The setup you are describing may be good to 600rwhp but that would be pushin it. Dual pump and 60# inj. would cover your goals.
Old Nov 10, 2007 | 06:20 PM
Spade's Avatar
Most guys I see just get the 60lb injectors. I have 50's right now with 500rwhp with no problems but if I were to do it again I would go with the 60's for more room to grow.
Old Nov 10, 2007 | 07:25 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
Look me up, I have all that you need to complete your system.
For more information, I can be reached at (724)322-8505
7:00pm-11:00pm eastern time weekdays & 9:00am-11:00pm weekends.
Old Nov 10, 2007 | 07:43 PM
sevanseriesta's Avatar
I have to agree w/blackhwk, as we have just about the same fuel setup
Old Nov 10, 2007 | 09:47 PM
SSilverSSurfer's Avatar
im putting mine together right, -8an feed with a -6an return, mototron 60lb injectors, speed inc rails, PP boost referenced FPR, and i plan on going with a Lonnies Double Pumper set up
Old Nov 10, 2007 | 10:23 PM
Spade's Avatar
I did fail to mention I am also running a 255 intake pump as well.
Old Nov 11, 2007 | 12:05 AM
Mike @ New Era's Avatar
Then you will be fine with some 60 lb injectors , and a hotwire kit for that walbro and you will be good to go . We have the hotwire kits in stock for $59 and the #60's are on sale right now at $379 (also in stock as always) , and I can also get you a flowmatched or flowtested set for only $419 ! You can order anytime here www.neweraperformanceparts.com , or if you have any questions or need assistance with anything you can call 585-865-1832 during business horus or email sales@neweraperformanceparts.com anytime .
Old Nov 11, 2007 | 10:54 AM
ChevyChad's Avatar
8 sec potential, 12 sec slip
For 600-650 you will definetely need 60#ers and you will also need more than just one 255. I'm running dual 255's and 60# injectors with rails and aeromotive FPR and using the stock hard lines along the frame rails with -6 line going from the tank to the hard lines, and -6 running to the rails from the hardline.
Old Nov 11, 2007 | 01:31 PM
Josh@MASPORT's Avatar
Closed Sponsor Account
my one walbro runs out at bad 4500rpm at 8psi, thats y i have 2
