injector question
Old Nov 15, 2007 | 01:56 PM
greyghost4x4's Avatar
Banging some gears
Default injector question
need to know what i have... i bought #42 svo greentops and my fuel pressure is 60.... car is running like **** and need some help fast!!
Thanks guys
Daniel
Old Nov 15, 2007 | 02:11 PM
69firebird's Avatar
has the car been retuned for the new injectors?
Old Nov 15, 2007 | 02:33 PM
Frost's Avatar
where is the question?
Old Nov 15, 2007 | 03:10 PM
Banging some gears
yea... still runs like ****
Old Nov 15, 2007 | 03:11 PM
Banging some gears
wanting to know what size my injectors really are... cause aparently a tune for 42lb injectors aint right.. car is running like ****
Old Nov 15, 2007 | 03:13 PM
69firebird's Avatar
describe a little better about how its runnings, is it pig rich?
any smoke, smell like gas, rough idle lil more info.
if rich, try lowering fuel pressure some
Old Nov 15, 2007 | 03:17 PM
Boodyrider's Avatar
And 60 fp is way too high
Old Nov 15, 2007 | 03:35 PM
ss1's Avatar
ss1
Really? I thought stock was 58psi...
Old Nov 15, 2007 | 03:36 PM
Banging some gears
car is running pig rich. black smoking, idleing rough as hell as if it is missing.
Old Nov 15, 2007 | 03:37 PM
Banging some gears
how is that too high? thats what it was stock
Old Nov 15, 2007 | 03:40 PM
ss1's Avatar
ss1
What have you done to your fuel system? Stock/Racetronix?
If you haven't changed anything fuel related other than the injectors, it must be the tune.
Old Nov 15, 2007 | 03:41 PM
69firebird's Avatar
I would say you've got too much fuel (obvious i know), try lowering the fuel pressure, see if that helps.
if not id call your tuner and make sure they adjusted for the injectors, your car wont be able to fix that much differnece in injector by itself, it would require tunning which you already said you got.
You havent said, but Im assuming the car ran fine, and then you added the injectors and it didnt run well any longer?
Old Nov 15, 2007 | 03:44 PM
Banging some gears
thats right... car was running perfect... decided i wanted to put a dry kit on it so i upgraded the injectors b/c of the demand for more fuel. now after having the computer retuned for the injectors and a little timing took out for the dry kit... it runs like ***
Banging some gears
how would i go about lowering the fuel pressure?
Old Nov 15, 2007 | 03:45 PM
Banging some gears
walbro 255lph fuel pump is all, well besides the injectors
Old Nov 15, 2007 | 03:50 PM
69firebird's Avatar
id call the tunner, it sounds like they have messed something up
did you swap the injectors at the shop right before the tune?
heres what I dont understand, if they tunned it for 42's and you went home on the stockers it should have ran bad too, then you swap in the 42's and it runs good/better.
but if it ran fine on the stockers, and then bad on the 42's i wouldnt think they actually tuned it for the 42's, it should have been way lean to the point of being dangerous with the smaller injectors in it.
if you did change them there at the shop while they were tunning, whyd you leave without it running right?
Old Nov 15, 2007 | 03:56 PM
Banging some gears
ok.. the car was already tuned for the cam/headers/ory/blablabla earlier this year.. ran perfect...
decided to do the injector swap so i got a mailorder tune for the injectors/cam/headers/ory/blablabla. put the injectors in.. uploaded the tune.. cranked the car and runs like ****... i didn't have the money nor the time to take it to a dyno to get it tuned there.
Old Nov 15, 2007 | 03:57 PM
Banging some gears
reason im buggin you guys on here is because i cant get intouch with my tuner... car runs fine once you get goin on down the road/ and runs good at WOT
Old Nov 15, 2007 | 04:14 PM
Banging some gears
im sure this has something to do with my car running pig rich but its throwing more water/condensation out of the exhaust tips than it ever has..
Old Nov 15, 2007 | 04:17 PM
Banging some gears
dam... its a bad coil pack!!! DOH
