? about walboro install
well i wanna install a walboro 255 lph pump i bought form a member here but it ddnt come with instructions. so im kind of confused about the install. im installing it on my 98 trans-am, well i read the sticky and the 98s dont have the fuel pump buckets. well ive already cut out the trap door and gotten the pump out with the sending unit. so im wondering if its just a direct replacement from there? well after searching i found this old thread https://ls1tech.com/forums/showthrea...ro#post2147281 and from what i can see in the pics. it looks like i have this same part number f20000169, so im not getting as too why this tech member had to switch the pump wires around because the pump ran backwards it seems, will that happen to mine? or should i just go ahead and do it and see what happens?
Here's a write up on a dual Walboro setup. There should be lots of good info and pics to help you do your single Walboro install.
http://www.camaroz28.com/forums/show...dual+fuel+pump
Or you could take a look at the 1st sticky located at the top of this thread
