Fuel system options for 750-800whp C6 vette
I have a feeling I will need more fuel than my stock system + BAP can provide after I forge my 6.0L and bump the boost. What other options are there? Considered adding an extra electric pump (ECS stage 2) or replacing the stock system and going with a dual in-tank solution like the APS Extreme Fuel system. Are there other options, if not which is better since the price is about the same?
LS1TECH Sponsor
I offer dual intank pump kits for the C6 Corvettes. Kits are available either fully assembled & tested with plug-n-play wiring harness or as a complete fuel system kit including braided lines, fuel rails, regulator, all fittings, & filter.
All kits are built exclusively using Racetronix quality components.
Kits have supported over 980rwhp to date with the limits not yet reached.
If you need more information, I can be reached at (724)322-8505. The best time for tech support is 7:00pm-11:00pm eastern time weekdays & 9:00am-11:00pm weekends.
