Best tank
Old Jan 13, 2008 | 12:49 AM
js2fst's Avatar
Default Best tank
What is the best gas tank to use?
Old Jan 13, 2008 | 12:52 AM
Frans96SS's Avatar
you talking aftermarket? if so i have used a few NASTY tanks in customer cars of mine and they work great....
Old Jan 13, 2008 | 01:17 AM
js2fst's Avatar
easy to install?
Old Jan 13, 2008 | 08:49 AM
MIGHTYMOUSE's Avatar
my factory tank is still working awesome at holding gas.
Old Jan 13, 2008 | 05:15 PM
Websy21's Avatar
I got a full aftermarket system but if I did it again I'd use my stock one with dual intank walbro's. will support up to 1000rwhp easy and reliable as hell, even DD street driven. Jsut make sure to keep minimum 1/4 tank. If you are stuck on aftermarket sumped tank I'd call up Nasty. Never seen one in person but they look great and many use them with great success on here. I beleive they install with stock straps but not 100% on that one. I know the one I have does but its not a sponsor on here.
Old Jan 13, 2008 | 05:51 PM
Frans96SS's Avatar
Originally Posted by js2fst
easy to install?
yes i never had a problem with one...
Old Jan 13, 2008 | 07:29 PM
if you put the twin pumps in a stock tank correctly you can run the fuel just as low as stock.
Old Jan 14, 2008 | 08:45 PM
DMH Fabrication's Avatar
I run Nate's tank in my car also. Everything bolted up great and i'm very happy with the quality of his work. I've also installed them in a few customers cars and have never had a problem. Nate is a great guy to deal with.
Old Jan 18, 2008 | 07:47 PM
99.9percenter's Avatar
Thumbs up
This is the best news I've heard all year. Thank You!
Old Jan 21, 2008 | 12:43 PM
Nasty N8's Avatar
Our tank fits in the factory location and hooks up just as stock. Also no need to keep 1/4 tank of fuel in our dual pump setup either.
Nate
Old Jan 24, 2008 | 06:02 PM
Drake's Avatar
That's a little like asking what the best gun is... it depends on what you need it for. What are your goals? Do you need a tank with a sump? Is noise an issue, or capacity? What about emissions?
The stock tank is hard to beat for most people. For those of us who require a sump, I hear good things about the "Nasty Performance" tank... or you could do like I did and build your own.
Again I have to say... what do you want to do with it?
