Strange fuel problem........
I just finished building my fuel system and it consists of dual Walbro's, dual -6 lines out of the tank to a big Y-block. -8 line to magnafuel filter, to the rails, then to a Fuelabs regulator with stock feed as return.
I also installed 2 hotwire kits with 10awg wires all the way to the pump's relays.
Now, it does the SAME thing (on 1 pump). Leaner when it gets hotter. The car has a 408 that makes 530-550rwhp MAX N/A. When it's warm outside, and I get it running perfect, it will start running super lean as it gets cold and I'll just have to command really rich to compensate. On 1 pump commanding fat, it runs 13.0:1, with both on, it runs right at 11.8 or so (what I'm commanding). I pulled the fuse on the primary pump, and ran it just on the spare pump, and it runs exactly the same as the primary pump alone. I figure this rules out anything being wrong with the primary pump itself. I tried to spray it for the first time last night with just a 50 shot to work out the kinks. I thought the spray was working because the A/F would change under WOT, turns out it was just because both pumps were on.
What is the deal? I have always thought that a single Walbro 255 could support 600rwhp? I thought for sure it would run even better with the hotwire/true return system. I don't really want to run 2-walbro's constantly, but will if need be. I get 13.4 volts on the pump side of the relays, which use 2' of 12awg. I have them grounded to one of the swaybar end link mount bolts, which goes directly into the framerail/unibody. I even grinded down the bolt head so they would make good contact with it. Could this be part of the problem?
I thought it was a tuning issue too, and I've been jacking with it for MONTHS with no end in sight. Night before last was the first time I've tried spraying it, and the first time I've run it on both pumps. I set the FJO's trigger to turn the nitrous on at 10k rpms so it wouldn't spray and I could just run it N/A on 2 pumps.
It may be worth noting that I'm at SEA LEVEL and it's like 40* outside. Uncorrected it's probably making above 550rwhp.
I do notice that with one pump on, if I just watch the gauge and rev it, it dips hard to about 40psi then comes back up. If I turn the second pump on, it BARELY moves with a rev.
Maybe my car makes a lot more power than I think it's making.
Thanks for the info though, I may just have to call it running out of fuel and run 2 all the time. The car is a weekend warrior and I have a lean shutdown switch on the nitrous kit (and fpss) so i'm not that worried about unknowingly loosing a pump and hurting something.
One is a walbro 340 other is a 341, not sure if that matters, but I got the 341 for free from a friend. The 341 has a little brass "venturi tube" that I just left open. I figured I had any problems associated with that stuff ruled out by running both by themselves with the same results.
The pressure bleeds off in the system pretty soon after the car is turned off. How long should it take?
Now once youre under load, the intake manifold and underhood temps are up, the difference will be much less. But don't be surprised if cold weather makes things change a little.
When the second pump comes on, it's only seeing the pressure it SHOULD, which is stay at 60psi, I have a real return system on the car. When one pump is on, the motor is consuming all the fuel from the single pump, which is just enough to run it 13.0 when it's 40* outside. The regulator actually CLOSES during WOT on 1 pump.
Everything is hooked up right. Regulator's boost port is open to atmosphere. I do have a Fluke I can check the ground with. There's about 2' of -6 off of each pump, then a big Y-block with 1/2" NPT x -AN threads, then probably 10' of -8 to the back of the passenger side rail. It's then got a -6 cross over and about 18" of -6 to the regulator.
I can understand a spike drop in fuel pressure due to the initial surge, but it stays down. I can stand on it from 3k to 7k and it will start leaning out around 5k.
Also, double check the fittings or hose clamps in the tank, on the pumps. The smallest leak in the tank will dramatically affect fuel pressure. Check that ground(s) for sure. Also, when you check the ground, leave the meter on for a few seconds and watch the display. A less than adequate ground can take a few seconds to show in the display. The number should be as close to zero as possible (the Fluke is like the Craftsman in that they smooth out jitter in the measurement).
Also, it may be that a single Walbro may not be able to adequately maintain your pressure on a -8 line with the demands of your injectors. Remember, pressure and volume are inversely proportional.
Lastly, (I am not telling you to do this, but) switching my car to full Speed Density was the best thing I ever did for my tuning headaches. Just my opinion, many will disagree, but I fought wild AFR curves for weeks and once I went SD, then tuned AutoVE and RAFIG... it was all butter.
Sorry about the long post, just trying to help you out bro, these kind of problems always **** me off too and I have had my share.
The rail that has the outbound -6 line to the regulator. Cap it off at the rail. Making it a deadheaded fuel system. Then turn on the key and see what the fuel pressure runs up to. It should skyrocket to well over 65-68 psi. If it doesnt, then you have a pump problem or a leak somewhere in the tank. This will not hurt the Walbros, they should be able to take running deadheaded.
The wideband is on the passenger side bank, which is the same bank that has the -8 plumbing to it directly from the tank, so if anything, it should be running RICHER on that side. The crossover is a -6. I figured with the passenger rail sucking down 300+hp worth of fuel, 450hp worth on gas, a -6 crossover would suffice, plus I already had it. My N20 system's fuel feed comes off the back of the passenger side rail via -8an x -8an x 3/8" NPT TEE right before the main feed hits the rail. When I first installed the regulator, I had it screwed in too far and the pressure went up to like 80psi with just turning the key on and having a single pump come on.
I can't run an SD tune on my '98 because it has a secondary VE table that is only 1/2 resolution. I also can't do a handy-dandy auto tune either lol.
A leak in the tank did cross my mind. I have -6 female x 1/4" NPT male adapters in the tank on the bottom of the -6 bulkheads, then 1/4" NPT female x 5/16" barb fittings on the bottom of those, with 5/16" high pressure hose running down to the pumps (about 8" worth).
