98 walbro pump install
1- Is there no problem with the electrical crimp connections being submerged in gas?
2- Another post recommends NOT using rubber fuel lines submerged due to deterioration isssues. Did it appear possible to re-use the stock ones for either supply or return lines?
Griff
get the clamps good and tight, and try to use the band style clamps as the worm clamps can cut up the hose
bare electrical connections are ok in the gas tank, just dont let them touch.
