-6 or -8 feed line
Old Jan 31, 2008 | 01:33 PM
Tiger2o69's Avatar
Default -6 or -8 feed line
Trying to figure out what size feed line to run.. I have been looking at running -8 but heard that that would be too much for a 700-750rwhp car.. -6 just doesnt look any bigger than stock.
right now im trying to use a single pump and run a braided feed line. I only want to make 600 or so on the single pump but later I would upgrade to dual in tank pumps.
I was told that the -8 would burn up my single pump. Is anyone running -8 with a single pump..
anyone running -6 with a dual pump? what rwhp numbers?
Old Jan 31, 2008 | 01:43 PM
Whistler's Avatar
Sawzall and Welder Mod
The -6 is about the same size as the OEM feed line (3/8). Until you're ready to step up to a return style system with aftermarket rails and a boost referenced regulator, the stock line will probably be fine.
Old Jan 31, 2008 | 01:46 PM
Zombie's Avatar
I'm running the stock lines/setup with dual pumps and it's been OK at my power level.
Old Jan 31, 2008 | 01:54 PM
stevieturbo's Avatar
That is complete and utter nonsense.
I recently tested my fuel system ( dual pump ), and while it has a -8 line from pumps to engine, return is a -6.
This was able to flow 486 litres per hour via that single -6 return. So clearly it doesnt pose much of a restriction, and that flow will easily support 1000+ and then some.
So a -6 or -8 would work fine for you...whichever is handiest to plumb in.
Old Jan 31, 2008 | 02:36 PM
MIGHTYMOUSE's Avatar
99% of the time my car is running is with a single walbro fueling through a -8 feed.
the 6 should flow more than the stock lines, which some people are even using at your level.
i would consider the expense of the line and your plans with the car, if you may upgrade to more hp in the future, just buy the -8 line instead of buying -6 now and -8 later
Old Jan 31, 2008 | 09:38 PM
Shawn @ VA Speed's Avatar
hey man-can you talk in gallons for us americans,lol
Old Jan 31, 2008 | 10:38 PM
Tiger2o69's Avatar
I have a magnafuel boost ref. regulator, magn. filter, fast rails, and 60lb injectors... Im just trying to set up a return system now.. Right now I have a single racetronix pump that I plan on running untill I decided what I want to do around cutting the bucket. I hate to do that because I drive 100-150 to college and back home on the weekends. I drive the car daily..
I appreciate the help.. -8 is only about $60 which is not significant and will allow me upgrade room in the future.. Probably the way I will go.. thanks
Old Feb 1, 2008 | 01:04 AM
US Gallons or UK Gallons
Old Feb 1, 2008 | 04:33 AM
Mr. Axe's Avatar
Everyone should use litres so there is no confusion about uk and us gallon
Old Feb 1, 2008 | 08:55 AM
Not to mention Quarts !!!! lol
Old Feb 1, 2008 | 11:35 AM
junior28570's Avatar
I figured you boys referred to everything in "pints"
... back on topic (ahem)
Old Feb 1, 2008 | 03:31 PM
Thats 855.6 pints of fuel per hour
Old Feb 1, 2008 | 04:43 PM
kp's Avatar
kp
Easiest thing to do with some room to grow is use the -8 for a feed line and the stock feed line as return. Works for me..
Old Feb 1, 2008 | 04:45 PM
qqwqeqwrqwqtq's Avatar
Fwiw we've used the stock feed line at 1,100+rwhp, so imo -6 is more than enough.
Old Feb 7, 2008 | 01:11 AM
Snyper's Avatar
I went -8 to the motor and -6 back.
Old Feb 7, 2008 | 08:26 AM
Hennytime's Avatar
as in th stock hard line with a return?
Old Feb 7, 2008 | 01:20 PM
Speed Density's Avatar
hashtagBMW
Same here. Should be around 825fwhp on my setup.
