Changing injectors to low IMP, need some help
Old Feb 12, 2008 | 04:21 PM
firefly9r68's Avatar
Question Changing injectors to low IMP, need some help
ok i am going from some simiens 60'g HIGH impedance to some simiens 83 low impedance injectors. Now the Injector manufacture said if i am not going to change them in and out i could get away with just putting in a resistor in line with the power wire on each injector. He says they do it all the time. This way i dont have to use the piggy back box, and would be easier to install. Well i have done most everything with a car but i have never ran across this so my question is, has anyone heard of this, and which wire is the right one to tie into on each injector, and what size resistor would i put inline with the 2.5 ohm injector?
Old Feb 13, 2008 | 12:10 AM
hal9000's Avatar
well the problem with running a resistor is that #1 your injector's will open slower, so your max usable Duty % number will go down, and you wont be able to get a decent idle because you can get control of the injector at low PW, but with ones that big i doubt you could get a good idle anyway. secondly, the 10 or 12 ohm resistor you put inline with each injector will have to be able to dissipate a lot of power (ie a 10 watt resistor) and each one will get pretty darn hot so you have to think about where you are going to mount 8 of the suckers. i guess a good resistance value would be what ever totals up with the new injectors to equal the stock injector resistance. so if stock was 16 you need about 13.5 ohms plus your new injectors.
i should preface this with i know lots about ECU design, but little about the GM one you are talking about so i have no idea if this would work, and i believe if it did, it would be way suboptimal. Not sure who sells "conversion" box's anymore, sorry.
Old Feb 14, 2008 | 05:42 PM
thanks for th input!!!
Old Feb 14, 2008 | 06:50 PM
stevieturbo's Avatar
Its been well covered here. Racetronix sell a plug n play low impedance driver system using an AEM box. ( or any other box if you want, Im sure )
Old Feb 20, 2008 | 06:25 AM
cablebandit's Avatar
i am using the versatronics box with my 96s....idles fine
Old Feb 20, 2008 | 11:49 AM
Nasty N8's Avatar
Ya use a good converter box. You will have issues as posted.
Nate
Old Feb 20, 2008 | 12:41 PM
Nate
Hi Nate,
OT.....but any updates on my intake/16 injector conversion ?
Old Feb 20, 2008 | 06:51 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
I stock the AEM impedence converter box with the Racetronix plug-n-play wiring harness assembly to make the install very easy.
Give me a call if I can be of assistance.
Old Feb 20, 2008 | 11:21 PM
Blackbird's Avatar
Synergy makes a standalone injector driver box.
Old Mar 1, 2008 | 05:18 PM
9secz's Avatar
Synergy and AEM make blatant ripoffs of the *patented* Acceleronics VersaFueler. I'm hoping at least a few of you will support American innovation by purchasing the original carefully engineered product rather than a cheap knockoff.
Jeff
