1 pump enough for turbo
Old Mar 2, 2008 | 12:20 PM
deadmanTA's Avatar
Default 1 pump enough for turbo
Is 1 GS 340 enough for a turbo car under 600rwhp and 8-9 psi max? I see the supercharger kits only give you one pump for low boost.
Old Mar 2, 2008 | 07:01 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
To be safe, I usually say 550rwhp, but many have gone higher without problems.... but some have issues above this level. It depends on your tune & the condition of your fuel system as well.
Old Mar 3, 2008 | 07:13 AM
deadmanTA's Avatar
Thanks
Old Mar 5, 2008 | 12:48 AM
dkrowner's Avatar
gs340 with msd boosta pump
Old Mar 5, 2008 | 02:58 AM
Tirefire's Avatar
I say no only because I'm at 525 rwhp (Mustang dyno numbers) and fuel pressure does not hold for me. Maybe if you have a fuel system with return lines and all, and your boost referenced, then yes. But I don't think that a factory setup with the regulator in the tank is going to work.. just my 2 cents..
Old Mar 5, 2008 | 08:37 AM
deadmanTA's Avatar
What would be better then; 1 GSS340, aeromotive compact fuel press. reg., return line OR 2 GSS340's (1 w/ hobbs switch).
Old Mar 5, 2008 | 09:06 AM
Tirefire's Avatar
That sounds like it would work, but I'm no expert. I have'nt fixed mine yet!! haha When I decide to fix mine, I'm going to go with lonnies double pump setup or I just might do what Mightymouse did..
Old Mar 5, 2008 | 09:21 AM
SSilverSSurfer's Avatar
ur basically running the same set up as me except I'm on a forged motor. Save urself the time and the trouble and just do lonnies doupble pumper set up. That's what I'm doing.
Twin 255's, -8an feed, br fpr, 60lb injectors, and a -6an return, Hobbs switch
Old Mar 5, 2008 | 06:25 PM
deadmanTA's Avatar
Ok should I get a second hotwire kit for the second pump and splice it into the one I already have?
Old Mar 5, 2008 | 09:06 PM
the hobbs switch should take care of that. it kicks the second pump on at a certain psi of boost. i think thats right. if not talk to lonnie and he will take care of you really good to work with
Old Mar 7, 2008 | 08:24 AM
deadmanTA's Avatar
But I still need power going to the hobbs, which will then feed it to the second pump when it hits a pre-set boost level don't I ?? Or am I looking at this all wrong?
Old Mar 7, 2008 | 10:05 AM
here read this thread, it should help a little
https://ls1tech.com/forums/fueling-injection/858869-duel-intank-hot-wired-vs-hobb-switch.html
