Which Injectors do I need?
Thanks for your help!
I was one of the ones that started out with 42s, to then have to turn around and get 60s because I was maxing out my 42s. Double the effort and double the money. If I would have known I was that close at the beginning It would have been a different story.
Idling rich, ummm... explain why you have to double the effort and double the money... all you would have to do to get the 60#ers to not run rich at idle would be to get a Fuel pressure regulator, and pay tuners big bucks??
there is a limitation on what an injector can operate at, meaning pulse width and such. At some point you CANNOT control some XXX lb/hr injectors because even with reduced fuel pressure(with fuel pressure regulator) ..etc etc they simply will not operate because they will be out of their specs
they make: (just a few of them) and these are based on 43.5psi rated
32#
37#
38#
42#
48#
52#
60#
63#
71#
79#
and also RCENG makes:
http://www.rceng.com/Peak-Hold-Fuel-Injectors-C5.aspx
A WHOLE LOT!!!! they can make you anything you want....
so you can work out somewhere in between there what you need
just curious, Urban Legend, what is your duty cycle on your 60#ers?
Here's the calculation:
So, looking at commonly available injectors on the market. A 36 lb would be the closest to your current requirement and has a little growth potential. A 42 lb would give you very significant growth capacity. This is all assuming you stay naturally aspirated. If you change to forced induction, the calculations significantly change.
Clear as mud?
HTH,
Injector Scaling and Sizing Write-Up
Robert
Robert
The program above isn't just a injector scaling utility like the one in HP Tuners. Fuel Injector Calculator from Performance Trends is designed to size injectors for an engine based on inputs. The utility in HP Tuners does not offer anywhere near the capabilities of FIC.
Robert
Robert
Here's a link to FIC: http://www.performancetrends.com/Fuel_Injector.htm
