need help on how to fix a pin hole in the fuel line running from the pump to the eng
some how my my fuel line got a pin hole in it i need some opinions on how to fix this because its pissing gas...
If it's a steel line and you just want a quick temp fix. Cut off about an inch of 3/8 fuel line and then cut the hose length wise. Put it on the line centered over the hole and put a F/I style hose clamp around it. I would not use this as a full on fix but it will hold till you can either get a new line or get time to pull it down and cut the bad piece out.
Re'
Re'
