walbro 255lph
Old Apr 22, 2008 | 03:05 AM
kbraklr's Avatar
Default walbro 255lph
how much hp can a walbro 255lph pump support?? can it support 9 psi from a turbo kit on an ls1 with lq9 heads? ~575 rwhp?
Old Apr 22, 2008 | 07:46 AM
ls1290's Avatar
Dumb Ass Vette Moderator
I think the 255L can support around 600ish NA. For FI, I would not push one past 525 to 550ish rwhp.
Keith
Old Apr 22, 2008 | 09:52 AM
MaxC5's Avatar
Hmmmm so for FI, what would be the next step? Especially at 9psi.
Old Apr 22, 2008 | 10:03 AM
ulakovic22's Avatar
https://ls1tech.com/forums/fueling-injection/856954-diy-twin-pumps-quick-cheap.html
Old Apr 22, 2008 | 11:40 AM
MaxC5's Avatar
That would be a stretch inside a 2001 C5 bucket. I'm leaning in that direction though, thanks for the link.
Old Apr 22, 2008 | 12:16 PM
ls1290's Avatar
It is possible to get twin 255L pumps into a C5 tank. It is a tight fit, but doable.
Keith
Old Apr 22, 2008 | 02:40 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
I make a plug-n-play twin intank setup for the C5 Vette if you are looking for a complete setup.
Old Apr 22, 2008 | 03:49 PM
MaxC5's Avatar
Default Twin 255s in tank for 2001 C5
Sorry to hi jack this thread
Currently I'm running a P1SC-1 with 42s, one 255 in tank, and KB BAP. I'm running out of fuel (starts to lean out) on the top end at around 5000 rpm making 8psi, and the fuel pressure drops from approx. 60 psi to 45psi (this is unacceptable). The injector duty cycles are over 120, I think Im running out of pump, I cannot see going to 60# injectors as I have stock heads and cam.
I have seen others run around 5 or 6 psi with a racetronix and BAP with no problem, but they are staying in the 470 to 500 rwhp range, I think I'm going to be over that.
Let me know what you think.
Later,
Max
Old Apr 22, 2008 | 04:30 PM
MaxC5's Avatar
Is this the kit you are referring to.....if so tell me more.
What is meant by "Requires your sending unit for modification"?
Early C5 Vette Double Pumper - Twin High Output Fuel Pump Kit, Wiring Harness & Hobbs Switch - Fully Assembled & Tested
1997-early 2003 RX-C5-GSS340-DP-PKG
Thanks,
Max
Old Apr 22, 2008 | 08:04 PM
LS1TECH Sponsor
I require your sender as I reuse the cover plate & the level sensor.
Kit retains the stock connections for ease of replacement & will work with stock lines. No tank modifications are required.
For more information, I can be reached at (724)322-8505
The best time to reach me for tech support is 7:00pm-11:00pm eastern time weekdays & 9:00am-11:00pm weekends.
