03 Cobra 39# injectors
You don't want to use these on an LS1. They spray in a 'V' pattern instead of a cone shape like and LS1 injector. These spray in a 'V' shape because the Cobra motors are 4 valve and the injector must feed both intake runners.
Sheit: Are you sure? I just bought a set of 36# off ebay from a 96 Cobra.
They will work, just not the good to run on a two valve motor. The spray pattern is a dual cone that aims the fuel at the intake port walls instead of on the back of the intake valve. Spraying fuel on the port walls causes fuel suspension problems that causes fuel puddling in the port.
