MSD BAP Install Questions
Anyone have any info on installing an MSD Boost-a-pump in an 02 Camaro LS1? I've done a number of Corvettes and GTO's but not a Camaro.
Which lead is the 12v Switched Fuel Pump Lead coming from under the Fuse Box?
Is there a place to tap into the fuel pump main leads or do you run the wire all the way back to the intank pump and install in place of the stock leads?
Other suggestions such as mounting location and wire routing?
Thanks!
Thanks!
