Dual walbro- is a hobbs switch necessary?
I'm from the world of mustangs and a lot of their systems don't utilize a hobbs switch. Other than requiring a bigger regulator, are there any downsides to not using a hobbs switch other than high fuel temps? Is there really a bump in fuel pressure when a pump kicks in during boost?
Also, what hobbs switch do you guys use?
LS1TECH Sponsor
If you have a properly sized return system, you can run both all the time. The negative result is a larger current draw on your alternator & higher fuel temps. The fuel has to absorb the additional heat from the pumps themselves, plus the heat from the engine compartment/fuel rails etc.
Some applications can experience pump cavitation on a hot day.
There is a reason fuel pump controllers are avaialble for all the big single pumps. Personally I do not like to run both continuously.
If done properly there is no need to run both pumps all the time & you will not have a large fuel pressure spike in your system.
This just convince me to run a Hobbs on my 2nd pump then. I already have underhood heat issues, I don't need my fuel getting any warmer.
So how to wire a Hobbs on my 2nd pump and where is a good place to get the switch? I generaly understand the Hobbs switch, I think. It detects boost and throws a switch (which is throwing a relay which throws the 2nd pump on)?
Jeff
Jeff
