loud injectors
Old May 6, 2008 | 10:37 PM
bigtim02ta's Avatar
Default loud injectors
i have a 02 trans am and the fuel injectors are making a loud ticking noise and was wondering how to fix it.
Old May 7, 2008 | 05:39 PM
bigtim02ta's Avatar
bumpsss
Old May 7, 2008 | 05:59 PM
TaterSS's Avatar
Some injector noise is normal, as long as they arent leaking down (causing long crank time at start up or causing a misfire) your better off just leaving it alone, only way to "fix" that problem is replace injectors...
Old May 7, 2008 | 06:29 PM
bigtim02ta's Avatar
no it starts right up just making a loud noise
Old May 8, 2008 | 07:47 AM
ZL1Killa's Avatar
are you sure its the injectors? ticking noise could be motor....
Old May 8, 2008 | 08:53 PM
bigtim02ta's Avatar
yeah put a long screwdriver on them some were louder than others i revved it up and it eventually went away a round 2k rpms but came back as soon as the motor came down.
Old May 8, 2008 | 09:54 PM
Mike @ New Era's Avatar
If you want to send them into to New Era , we can test them for you .
Old May 9, 2008 | 05:58 PM
bigtim02ta's Avatar
id like to do that but cant go with out my car.
Old May 9, 2008 | 08:34 PM
ZL1Killa's Avatar
then order new injectors. problem solved. get them tested and then sell them
Old May 10, 2008 | 12:04 AM
2002_Z28_Six_Speed's Avatar
What do you charge for a set? Do do you give any flow numbers? Thank you.
Old May 17, 2008 | 10:13 PM
1BadAction's Avatar
automotive hypochondria... injectors make noise. live with it, IMO.
