36 lb injectors.. what are they at 58psi?
please guys... does no one look at the stickies:
https://ls1tech.com/forums/fueling-injection/293742-fuel-injector-size-calculator-fuel-pump-chart.html
injector lb/hr RATING * (SQRT ( YOUR FUEL PRESSURE / RATED FUEL PRESSURE) )
For EXAMPLE:
an injector is rated 32 lb/hr @43.5psi
your fuel pressure is 60psi
To find out the new lb/hr flow rate the formula is:
32* (SQRT (60 / 43.5) ) = 37.58 lb / hr
For EXAMPLE:
u need to see what pressure they are rated @, I made some assumptions for u. I hope it won't go out of them:
36 lb/hr at Rated pressure (psi)--------flow (lb/hr) at 58 psi
39.5----------------------------------43.62324314
43.5----------------------------------41.56921938
45.0----------------------------------40.87052728
I have a 99 Trans am thou , but is it true that if you start going so high on A fuel injector , does it start to loose voltage , and you need to get a MSD voltage booster , where is the cutoff point , if i got a 42lb injector will i need to get a MSD box ??
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
F.A.S.T. 36 lb. Fuel Injectors, Emissions-Legal
F.A.S.T. 36 lb. Fuel Injectors, Emissions-Legal, LS1/LS6, Rated at 43 psi Fuel Pressure part # 111-303608
but with the fast i will need the Katech injector spacers since im using LS2 fuel rails and LS2 intake for the mean while
or the
F.A.S.T. 46 lb. Fuel Injectors, For LS2
F.A.S.T. 46 lb. Fuel Injectors, For LS2 Fuel Rail & Harness, Rated at 58 psi Fuel Pressure
More Detail part # 111-30462-8
What do you think ? for my 402cid ??? i dont need the MSD ? i got some 33/lbhr Fast , but there going to be too small i guess so what you think ?
or the
or the
or the
