Purpose of fuel tank pressure sensor
Old Jul 24, 2008 | 05:04 PM
Frostbite's Avatar
Default Purpose of fuel tank pressure sensor
What is the purpose of the pressure sensor on top of the tank bucket (looks like a map sensor). If it is related to the evap, and I remove the evap, do I still need the sensor?
Old Jul 25, 2008 | 10:16 AM
zman1969's Avatar
Default tank pressure sensor
emission related , I believe it senses pressure so ECM can verify no evap system leak. if no pressure system therefore would have a leak- bad gas cap or leaking evap line
Old Jul 25, 2008 | 03:43 PM
XpEdItIoUs's Avatar
exactly, you would have to disable the codes from the pcm if you ever remove your evap and vent into the world.
Old Jul 25, 2008 | 05:19 PM
MeentSS02's Avatar
Kleeborp the Moderator™
I concur...it is related to EVAP. You just have to go in and delete the codes related to it, and that's it.
Old Jul 30, 2008 | 10:21 AM
mterveen's Avatar
+1^ I removed all my evap stuff, and used the pcm wiring for the fuel tank pressure sensor instead for my autometer fuel pressure sending unit.
Old Jan 9, 2010 | 05:09 PM
Big_Bird_WS6's Avatar
^^^ so can i just remove it and plug the hole if i am deleting evap?
Old Jan 9, 2010 | 05:50 PM
XpEdItIoUs's Avatar
I wouldn't plug the hole because you will have pressure build up inside the tank. Just add a hose with a breather filter on the end of it.
Edit. If you talking about removing the sensor and pluging the hole then yes. But add a hose and breather to the nipple that would go to your evap canister.
Old Jan 9, 2010 | 07:10 PM
i mean the sensor
